Continue
  • My Subscriptions
  • Events
PM5310 Firmware update fails at 18.9%
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM5310 Firmware update fails at 18.9%
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
PowerLogic PM5000 series
BZsala
BZsala
Explorer
Posted: ‎2025-06-16 07:02 AM
2417
I have tried several ways to update firmware on the Schneider PM5310 through a PAS600 panel server, but  DLF3000 always throws a code 516 at exactly 18.97%
Tried on several separate devices, from PAS800, PAS600, locally, through network, etc. and always the same results.
  • Thumbnail of PowerLogic PM5000 series
View products (1)
  • PM5000
Tags (4)
  • DLF3000
  • firmware
  • pm5310
akash_das
akash_das Troubleshooter
Troubleshooter
Posted: ‎2025-06-18 09:35 PM
2394
Hi @BZsala in DLF300 device error= 516 means device failed to respond. Please check the communication stability of the meter with PAS600. Try connecting one to one with one meter. Also check & adjust the Modbus serial communication parameters.
Replies 5
Jesus_Diaz
Jesus_Diaz Leader
Leader
Posted: ‎2025-06-18 02:32 PM
Hi @BZsala,
What is the current firmware version of the meter, and which version are you trying to upgrade to?
Best regards,
JD
akash_das
Troubleshooter
2394
BZsala
BZsala
Explorer
Posted: ‎2025-06-18 09:38 PM
2389
Actually I have did exactly as You said, connected the unit directly to the PAS600 and this did the trick.
Although I still don't understand why it was failing exactly at 18.97%, even on different devices (PAS800, PM5320). Schneider should investigate this further.
Jesus_Diaz
Jesus_Diaz Leader
Leader
Posted: ‎2025-06-19 06:07 AM
2383
Can you please confirm the original FW and upgrade target FW?
BZsala
BZsala
Explorer
Posted: ‎2025-06-20 12:55 AM
Original FW, I am not sure, maybe 2.013? At least that's what the DLF3000 was shown.
The updated Fw is PM5110_PM5310_PM5330_v2.2.4_HW_vB1.
