Continue
  • My Subscriptions
  • Events
Displacement PF and True PF difference at PM5330
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Displacement PF and True PF difference at PM5330
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
Caglar_Abatay
Caglar_Abatay Mentor
Mentor
Posted: ‎2021-02-26 05:55 AM
4177
We used PM5330 series power meters at our project. There is a wrong values at some points. Displacement PF's are good but  True PF's are low.
What is the difference between Displacement PF and True PF?
How calculate PM5330 Real Power?
If PM5330 uses the True PF for calculate Real Power, can we change the calculation method of Real Power with Displacement PF?
Thanks.
  • PM5000
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2021-03-01 11:16 PM
2
4157
Sure @Caglar_Abatay
You can write to the offer marketing manager of this range (Shreesha PANDITH <shreesha.pandith@se.com>) to consider this requirement in future.
Ramasamy N
Replies 7
Charles_Murison
Champion
Posted: ‎2021-02-26 08:31 AM
4174
Hello @Caglar_Abatay
True power factor includes harmonic content.
Displacement power factor only considers the fundamental frequency.
Questions regarding the PM5330 I will need to leave to @Ramasamy_N
Charles
Caglar_Abatay
Mentor
Posted: ‎2021-02-28 10:11 AM
Thank you @Charles_Murison
Hello @Ramasamy_N , Can I change the calculation method of PM5330's Real Power as Displacement Power Factor via ION Setup etc?
Best Regards.
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2021-02-28 09:37 PM
4
4165
The PM5330 calculates the real power based on True PF value. There is no option to change the power calculation based on Displacement PF.
If the actual waveforms are pure, the True and Displacement PF will be equal. When the load has harmonics, the true PF will be less than the Displacement PF.
Ramasamy N
Caglar_Abatay
Mentor
Posted: ‎2021-03-01 10:04 PM
4159
Hello @Ramasamy_N ,
Load has harmonics and  the true PF will be less than the Displacement PF.
It would be great if there was a replacement option of calculation.
Best Regards.
Ramasamy_N
Ramasamy_N Champion
Champion
2
4157
Sure @Caglar_Abatay
Ramasamy N
DanL
DanL Champion
Champion
Posted: ‎2021-03-02 10:01 AM
It sounds like the feature/quantity you are asking for is called "fundamental active power" and probably also "fundamental active energy".
I believe that gapless measurement (aka. zero blind) of fundamental or any spectral component of a signal is generally thought to be a more advanced feature. All fundamental power quantities (active, reactive, and apparent) are gapless and available by default on the PM8000 series meters.
https://www.se.com/ca/en/product-range-presentation/62252-pm8000-series/
ShreeshaPandit
ShreeshaPandit Explorer
Explorer
Posted: ‎2021-03-04 09:35 AM
Thanks @Ramasamy_N
@Caglar_Abatay : We will investigate about the possibility of providing option for calculating power using distortion PF.
Regards
Shreesha Pandith
