Continue
  • My Subscriptions
  • Events
Connecting to ION 8650 via Direct Ethernet Connection
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Connecting to ION 8650 via Direct Ethernet Connection
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
PowerLogic
PowerLogic ION8650 series
berickson
berickson
Explorer
Posted: ‎2022-06-07 05:11 PM
2494
Hi Team,
Is it possible to establish a direct ethernet connection between an ION 8650 and ION setup? If so, are there any instructions on how to do this?
I've heard it is possible, but I'm having trouble figuring it out.
Thank you,
Brandon
  • Thumbnail of PowerLogic ION8650 series
    PowerLogic
View products (1)
  • ION Setup
  • PM8000
Charles_Murison
Champion
Posted: ‎2022-06-08 09:35 AM
Hello @berickson,
There are some assumptions that need to be made first. First assumption is you have an ION8650 meter that supports Ethernet. Second assumption is that IP address of meter and PC are in the same subnet. If subnet is 255.255.255.0 for example, the IP address has to have the first 3 octets match. For example if Meter's IP address is 10.10.10.5, the PC IP address needs to be 10.10.10.X, where X is 0 to 255 (excluding 5).
Another assumption is that meter has ION over Ethernet enabled. This is enabled by default but can be configured on later versions of firmware.
As for connecting to the meter, the physical connection is simple, connect the Ethernet cord from the meter and plug into computer.
Charles
Charles_Murison
Champion
Hello @berickson,
Charles
