Continue
  • My Subscriptions
  • Events
How to Setting the SNTP of IEC61850?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • How to Setting the SNTP of IEC61850?
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
jryang_SAM-A
jryang_SAM-A
Explorer
Posted: ‎2022-06-03 01:09 AM
2393
HI Everyone
I am reading ION8650 Data using IEC61850.
If NTP and SNTP time synchronization is performed on the ION8650, is there any work that needs to be done separately?
Or is it done if I set NTP and SNTP in Advanced Ethernet in the ION Setup I know?
If I need to set it in .CID and other places, I wonder how to proceed.
Regards
JungRyeol
  • ION7000
  • ION8000
  • ION9000
  • PM8000
Charles_Murison
Champion
Posted: ‎2022-06-03 08:26 AM . Last Modified: ‎2022-06-09 04:30 PM
1
2382
Hello @jryang_SAM-A ,
IEC61850 does not make any communication changes to the meter via the CID file. Any communication settings need to be programmed onto the meter via ION either ION Setup or Power Monitoring Expert Designer or front panel.
Charles
Charles_Murison
Champion
1
2382
Charles
jryang_SAM-A
jryang_SAM-A
Explorer
Posted: ‎2022-06-09 12:45 AM
HI @Charles_Murison
OK i understood
Thank you
