Can I use the device configuration feature in IT Expert for NetBotz?
ITE FAQ
Answers to common questions about using EcoStruxure IT Expert
Send InviteCancel
You can use IT Expert device configuration for the NetBotz Rack Monitor 200 and NetBotz Rack Monitor 250 only.
NetBotz 355, 455, 450, 570, 750, and 755 are not supported at this time.
Only the values exposed in the config.ini for both the source and destination APC SNMP device can be configured. User management settings may not be available on some devices.
