Mount a remote filesystem on the Gateway appliance - version 1.10 and newer
EcoStruxure IT Gateway appliance
Support for EcoStruxure IT Gateway Appliances ends in December 2023. Learn how you can migrate to a new installation of the Gateway software.
  • EcoStruxure IT Help Center
  • Gateway
  • EcoStruxure IT Gateway appliance
  • Mount a remote filesystem on the Gateway appliance - version 1.10 and newer
  • Mark as Read
  • Replacing your EcoStruxure IT Gateway appliance
  • What's new in the EcoStruxure IT Gateway appliance
  • How to reset a lost administrator password for the...
  • Troubleshooting tips for mounting a filesystem usi...
  • Mount a remote filesystem on the Gateway appliance...
  • Managing DHCP on the Gateway appliance private net...
  • How to set a static IP address on the public netwo...
  • How to set a static IP address on the private netw...
  • How to restart the DCHP server on a Gateway applia...
  • How to resolve Gateway appliance cloud connectivit...
  • Gateway appliance management options - version 1.1...
  • Gateway appliance command line interface (CLI) - v...
  • Configure backup on a Gateway appliance - version ...
  • EcoStruxure IT Gateway appliance known issues
EcoStruxure IT Support
Request Support
Back to EcoStruxure IT Gateway appliance
  • Mark as Read
Picard EcoStruxureIT
‎2021-06-07 12:13 AM
To access the Gateway appliance private network CLI:
    1. Connect a computer to the same private network as the Gateway appliance.
    2. Use an SSH client to log in to the Gateway CLI using your Gateway user credentials, default SSH port 22.
idea_icon_360017797957.pngidea_icon_360017797957.png Press Tab after a command to see command suggestions.
fs config
Show mounted filesystems
fs config example
fs config
|Status|Source |Target |Options |
|AUTO |nfs:192.168.0.2/home/dev/share |/mnt/linux/share|[defaults]|
|AUTO |cifs://192.168.0.3/share |/mnt/share |[] |
|AUTO |cifs://192.168.0.3/Users/dev/Desktop/share%7C/mnt/your_share |[] |
fs show
Show NFS or SMB mounts available to the appliance from a remote host.
fs show
fs mount
Mount a remote filesystem to configure remote backups.
GWA_110_fs_mount_commands_4402283641361.pngGWA_110_fs_mount_commands_4402283641361.png
NFS mount example
gateway>fs mount --for-backups --from nfs://192.168.0.2/home/dev/share --to /mnt/your_share
successfully mounted nfs://192.168.0.2:/home/dev/share to /mnt/your_share
/mnt/your_share will be used as the backup destination
SMB mount example
fs mount --for-backups --from smb://192.168.0.3/Users/dev/Desktop/share --to /mnt/your_share
remote share user: username
remote share password: **************
successfully mounted smb://192.168.0.3:/Users/dev/Desktop/share to /mnt/your_share
fs unmount
Unmount a mounted remote filesystem
fs unmount example
fs unmount --mount-point /mnt/your_share
This is the current backup destination. Are you sure? [y|n] y
successfully unmounted /mnt/your_share
The new backup destination will be "/opt/EcoStruxureITGateway/backups"
See Troubleshooting tips for mounting a filesystem using the Gateway appliance private network CLI - ver...
Comments
wasabi
Lieutenant JG wasabi Lieutenant JG
Lieutenant JG
  • Mark as Read
‎2024-03-27 06:43 PM
Hi team,
is there a command to mount this on to USB ? thanks
