How to set a static IP address on the private network of the Gateway appliance (LAN2 or Gb2) - version 1.10 and newer
EcoStruxure IT Gateway appliance
Support for EcoStruxure IT Gateway Appliances ends in December 2023. Learn how you can migrate to a new installation of the Gateway software.
  • EcoStruxure IT Help Center
  • Gateway
  • EcoStruxure IT Gateway appliance
  • How to set a static IP address on the private network of the Gateway appliance (LAN2 or Gb2) - version 1.10 and newer
  • Mark as Read
  • Replacing your EcoStruxure IT Gateway appliance
  • What's new in the EcoStruxure IT Gateway appliance
  • How to reset a lost administrator password for the...
  • Troubleshooting tips for mounting a filesystem usi...
  • Mount a remote filesystem on the Gateway appliance...
  • Managing DHCP on the Gateway appliance private net...
  • How to set a static IP address on the public netwo...
  • How to set a static IP address on the private netw...
  • How to restart the DCHP server on a Gateway applia...
  • How to resolve Gateway appliance cloud connectivit...
  • Gateway appliance management options - version 1.1...
  • Gateway appliance command line interface (CLI) - v...
  • Configure backup on a Gateway appliance - version ...
  • EcoStruxure IT Gateway appliance known issues
EcoStruxure IT Support
Request Support
Back to EcoStruxure IT Gateway appliance
  • Mark as Read
Picard EcoStruxureIT
‎2021-02-18 07:51 AM
The Gateway appliance private network IP address is statically assigned 192.168.0.1 by default.
  1. Connect a computer to the same private network as the Gateway appliance.
  2. Confirm that your computer received a DHCP address from the Gateway. Its address will be 192.168.x.x.
  3. Open a browser.
  4. Go to https://192.168.0.1 to connect to the Gateway appliance private network and log in.
    • Click Manage Gateway appliance.
    • Select Private network and then Disable DHCP server.
    • Specify the static IP address and subnet mask for your Gateway and click Apply.
      Note: Be sure to select a nonroutable IP address scheme.
GWA_private_network_DHCP_disabled_360017766057.pngGWA_private_network_DHCP_disabled_360017766057.png
