How to resolve Gateway appliance cloud connectivity failure - version 1.10 and newer
EcoStruxure IT Gateway appliance
Support for EcoStruxure IT Gateway Appliances ends in December 2023. Learn how you can migrate to a new installation of the Gateway software.
Send InviteCancel
Note: With Gateway 1.10 installed, the NUC takes up to 8 minutes to initialize. The Dell takes just a few minutes.
Symptoms
When you are connected to the private network on the LAN2/Gb2 port, the Gateway login screen does not appear. The spinner is stuck.
You can connect to the private network interface but the public network connection is down and the Gateway application is unreachable.
The most likely cause is a network conflict.
Make sure your network cables are properly connected.
Adjust your network settings to eliminate any network overlap.
If you chose a nondefault Gateway appliance private network IP address, make sure the Gateway appliance private network IP address is not part of the DHCP scope; that is, the Gateway's IP address should not fall in the range defined by the DHCP starting and ending IP addresses.
