Configure backup on a Gateway appliance - version 1.10 and newer
EcoStruxure IT Gateway appliance
Support for EcoStruxure IT Gateway Appliances ends in December 2023. Learn how you can migrate to a new installation of the Gateway software.
  • EcoStruxure IT Help Center
  • Gateway
  • EcoStruxure IT Gateway appliance
  • Configure backup on a Gateway appliance - version 1.10 and newer
  • Mark as Read
  • Replacing your EcoStruxure IT Gateway appliance
  • What's new in the EcoStruxure IT Gateway appliance
  • How to reset a lost administrator password for the...
  • Troubleshooting tips for mounting a filesystem usi...
  • Mount a remote filesystem on the Gateway appliance...
  • Managing DHCP on the Gateway appliance private net...
  • How to set a static IP address on the public netwo...
  • How to set a static IP address on the private netw...
  • How to restart the DCHP server on a Gateway applia...
  • How to resolve Gateway appliance cloud connectivit...
  • Gateway appliance management options - version 1.1...
  • Gateway appliance command line interface (CLI) - v...
  • Configure backup on a Gateway appliance - version ...
  • EcoStruxure IT Gateway appliance known issues
EcoStruxure IT Support
Request Support
Back to EcoStruxure IT Gateway appliance
  • Mark as Read
Picard EcoStruxureIT
‎2021-05-26 07:20 AM
You use the private network command line interface (CLI) to perform backup configuration and one time backup on a Gateway appliance version 1.10 and newer. Local or remote terminal access is required to create and maintain Gateway backups.
Backup files are stored to the local file system. The Gateway is automatically backed up on a weekly schedule. See Backup schedule
Backup files can be stored on a remote system of your choice, independent of the Gateway appliance, as a one time or recurring task.
See Mount a remote filesystem on the Gateway appliance - version 1.10 and newer
Create a one-time backup
  1. To access the private network CLI:
    1. Connect a computer to the same private network as the Gateway appliance.
    2. Use an SSH client to log in to the Gateway CLI using your Gateway user credentials, default ssh port 22.
    3. Type backup run
      Output is displayed with the Gateway backup id, name, date, and other version information.
Backup files are stored locally on the Gateway server file system. From here, the file can be copied or configured for export to a remote file share.
Backup config options
Some aspects of the backup are configurable by adding the config parameter to the backup command.
View the backup configuration
backup config
View the backup configuration settings.
idea_icon_360020724917.pngidea_icon_360020724917.png Press Tab after a command to see command suggestions.
Configure the backup password
You will be prompted for a new password to use for encrypting backups.
backup config --archive-password
Configure the backup destination
Set the directory used to store backup file contents.
backup config --destination <file path>
Configure the maximum number of backups to keep
Set the maximum number of backup entries to store before rotating older entries.
backup config --rotation <maximum number of backups to store>
Backup schedule
Set the schedule of backups. The default settings are to backup on Sunday at midnight each week.
--repeat accepts one of the following values: monthly, weekly, daily, or hourly.
--on accepts one of the following values when repeat is weekly: monday, tuesday, wednesday, thursday, friday, saturday, or sunday. When repeat is monthly it accepts the day of the month instead (see examples below).
--at accepts time in twelve or twenty four hour format with hours separated by a colon. Valid examples: 8:00am, 14:00, 2:00pm, or 03:00pm.
Weekly backup example
Backup will run every Tuesday at 14:00 (2pm).
backup schedule --repeat weekly --on tuesday --at 14:00
Monthly backup example
Backup will run on the 15th of each month at 08:00 (8am).
backup schedule --repeat monthly --on 15 --at 8:00am
Daily backup example
Backup will run every day at 14:00 (2pm)
backup schedule --repeat daily --at 2:00pm
Hourly backup example
Backup will run every hour
backup schedule --repeat hourly
Disabling scheduled backup
Scheduled backup will be disabled
backup schedule false
Re-enabling scheduled backup
Scheduled backup will be enabled with the default backup schedule.
backup schedule true --repeat weekly
