Posted: 2021-06-28 12:48 AM . Last Modified: 2024-03-27 03:47 AM
I logged into the unit via the web interface with the default username of "apc" and default password of "apc". Used IE of course since Firefox isn't supported.
I went and tried to change the username and password. I used a complicated password that had capital letters and an Exclaimation point "!" in it. And I change the username to "admin". I hit ok and it said are you sure, and I said "yes". Now I can't log in. It is like it scrambled my password. I'm 100% sure I know the password, and since the password box didn't obfuscate it, I know i didn't misstype it when I originally typed it in.
I tried popping the front cover off of the unit and doing a manual reset with a paperclip. I did that while the unit was turned on, with the unit turned off, and even with the unit unplugged. Tried it for 5 seconds like the manual says, even tried for up to 30 seconds. Tried holding it while powering it off, unplugging, and powering on. Nothing works. When I try to log back in with the original username/password of apc/apc, it won't take it.
What can I do? Is this defective and do I need to return the unit to the place of purchase? Is there another way I can reset the password? maybe some other utility I can run?
Thanks in advance!
Dave
Posted: 2021-06-28 01:11 AM . Last Modified: 2024-03-27 03:39 AM
APC Back-UPS HS 500
AB0733821473
Could you also list what characters ARE allowed for the benefit of all?
Please send backdoor credentials:
Model: APC Back-UPS HS 500
Serial number: AB0919806498
Thank you very much.
I Have the same password problem.
My Serial: AB0503242310
Can you send me credentials?
Posted: 2021-06-28 01:12 AM . Last Modified: 2024-03-27 03:39 AM
Credentials has been sent on your PM Minie.
I have the same problem too. My SN is 3B1041X54301
Tom
A PM has been sent to tkski
Posted: 2021-06-28 01:12 AM . Last Modified: 2024-03-27 03:38 AM
Thomas, please check your Inbox and use the detail provided to login to your BH500NET.
Hello
Please help!
Serial AB0952295347
Many thanks.
Jon P,
Could you please send backdoor credentials:
Posted: 2021-06-28 01:13 AM . Last Modified: 2024-03-27 03:38 AM
Thanks Jon P.
please help me, blocked password to my APC Back-UPS HS 500.
Serial number: AB0851826566
Firmware revision: l1
Thanks for help.
L.
Again, my serial is "AB0851826566", can you send me please recovery username/password?
Thanks.
PM sent to Transall
Having the same problem.
Serial# - AB0438141750
Thanks!
I just found this thread and I've got the same problem. 😛 My serial number is AB0438341178. Thanks!
Posted: 2021-06-28 01:14 AM . Last Modified: 2024-03-27 03:38 AM
Hi Aaron,
Login credentials has been sent thru PM.
I just found this thread and I've got the same problem. My serial number is AB1014841898. Thanks
Credentials has been sent.
To all those who requested for the BackUPS HS 500 Net username and password please check your PM inbox. A login ID and password has been sent already.
can you give me the password please here is the serial
3B1126X17350
bh500net
thanks
Same thing here.
Please send me backdoor password.
Serial number: AB1014848493
Sorry for the delay, to all of those who requested for their log-ins please check your Forum Inbox. I have sent a private message.
Posted: 2021-06-28 01:15 AM . Last Modified: 2024-03-27 03:38 AM
vicg, kindly check your Inbox and use those details to login to your BH500NET.
I have the same issue. My serial number is 3B0949X30010. Thanks in advance.
Posted: 2021-06-28 01:15 AM . Last Modified: 2024-03-27 03:37 AM
A PM has been sent to jhack
Credentials sent via PM.
Have the "can't log in" problem as many others have had.
Serial number 5B0848T40259.
Well, I hope that's the serial number.
Thanks for the backdoor credentials.
Didn't work for me for some reason.
The web interface tells me the the s/n is
AB0848840259
Are the credentials the same as for the
s/n from the tag that I sent?
Posted: 2021-06-28 01:16 AM . Last Modified: 2024-03-27 03:37 AM
Same problem here. Serial number is AB1130837745. Thanks.
PM sent. I hope it helps!
Hi there. The UID and PWD credentials supplied didn't seem to work. On closer inspection, serial number on the physical unit is 3B0949X30010, however from the web interface it states AB0949830010. Is there a difference? Thanks again.
For The Software Telling You The Serial Is Different Open A New Post or the ui it telling the serial of the network card, And how did u get the s/n from the web ui without the password !!!!!!!!
Message was edited by: Wwallender
The APC software is giving me a different UPS Serial, on mine there is an "about" tab and it lets me go on it with out loging in, but if i try and change any settings or run a self test, i have to login and cant
Message was edited by: ljb123
Posted: 2021-06-28 01:17 AM . Last Modified: 2024-03-27 03:37 AM
Please send backdoor password.
Serial number: AB0803807232
Message was edited by: gavrila
gav,
Please check your e-mail.
Hi Techie
It worked! Can now get back in to the UPS config.
Best wishes
Jean-Paul
I sent you another PM jhack.
I have the same problem:
SN AB0803807509
I also have a Back-UPS HS 500 that I am locked out of. It's serial number AB0521343861.
Would you please send the back door credentials?
Thanks!
Posted: 2021-06-28 01:18 AM . Last Modified: 2024-03-27 03:37 AM
A PM has been sent to hakoch.
YES! It's finally works! Thanks, guys.
Hi Buzz
Thanks for the offer - the unit is a BH500INET and the serial number is AB0549242437 Any help on this would be really appreciated as APC's support in Europe either don't know or can't be bothered to retrieve the fix outlined to RangerDave.
I took this up with APC's online chat this afternoon (from the UK site) as they didn't bother to reply to the support request on 11 April. The initial response is outlined in my previous post. When this didn't work, I contacted them again via chat and after 20 minutes of no response and finally a disconnect from them at 5pm UK time, I gave up.
It's not really the kind of support I expected from a company like APC (having specified and used APC products in data centers), and it really lets them down in terms of corporate image. If they only want to support corporate customers it would be more honest to say so up front.
Updated by jplf
Posted: 2021-06-28 01:18 AM . Last Modified: 2024-03-27 03:36 AM
You're welcome Topan.
Hello, I have the problem of the username and password unrecoverable with the reset default, my UPS has a serial AB0745824189
please help me.
Using this "rig" for about 2 years - can't acces menu any more 😞
Serial number is AB1014851881
Could someone leade me the way in again - thnx!
Message was edited by: Richard.Hemme
Posted: 2021-06-28 01:19 AM . Last Modified: 2024-03-27 03:36 AM
Please - I need help! I have a HS500 and used an explanation point in the password and am now locked out. The serial number on the unit is: 3B1216X09820.
Thank you.
Message was edited by: jdk59404
Could we have an official response from APC about these ongoing flaws with the HS 500? Is there a revision model that we can be offered as an upgrade? Strangely this model appears now to have been removed from the UK APC site, with nothing equivalent to replace it. Allowing browser access using 1990's browsers only is ridiculous. I cannot get Safari, Firefox, Opera etc to work at all.
Glad it worked!
