bh500net APC Back-UPS HS 500 username and password problem
  • bh500net APC Back-UPS HS 500 username and password problem
2150
125
Posted: ‎2021-06-28 12:48 AM . Last Modified: ‎2024-03-27 03:47 AM
43790
I logged into the unit via the web interface with the default username of "apc" and default password of "apc". Used IE of course since Firefox isn't supported.
I went and tried to change the username and password. I used a complicated password that had capital letters and an Exclaimation point "!" in it. And I change the username to "admin". I hit ok and it said are you sure, and I said "yes". Now I can't log in. It is like it scrambled my password. I'm 100% sure I know the password, and since the password box didn't obfuscate it, I know i didn't misstype it when I originally typed it in.
I tried popping the front cover off of the unit and doing a manual reset with a paperclip. I did that while the unit was turned on, with the unit turned off, and even with the unit unplugged. Tried it for 5 seconds like the manual says, even tried for up to 30 seconds. Tried holding it while powering it off, unplugging, and powering on. Nothing works. When I try to log back in with the original username/password of apc/apc, it won't take it.
What can I do? Is this defective and do I need to return the unit to the place of purchase? Is there another way I can reset the password? maybe some other utility I can run?
Thanks in advance!
Dave
  • 500
  • bh500
  • exclamation
  • hs
  • login
  • net
  • password
  • problem
  • ups
Replies 271
  • « Previous
    • 1
    • 4
    • 5
    • 6
  • Next »
Posted: ‎2022-03-21 03:21 PM
In response to APC_Matt
2952
Hi Matt, BillP
I've this same problem, i.e. changed the password of my unit, and accidentally put in some character that the unit does not like.
Would you be able to help me with this issue please? The s/n of my unit is AB1126817134.
Thank you very much, your help is greatly appreciated!
Best regards,
Juha
APC_Matt
Lieutenant JG APC_Matt Lieutenant JG
Lieutenant JG
Posted: ‎2022-03-28 05:37 AM
In response to Anonymous user
2949
Hi Juha
I've sent you a Direct Message with a username and password
Regards
Matt
Hub
Crewman Hub
Crewman
Posted: ‎2022-07-26 08:24 AM
I have the same problem.
Cannot access the interface.
Can you please send me the backdoor password?
Model: APC Back-UPS HS 500
Serial: AB1517801717
Hubert
damian_d
damian_d
Cadet
Posted: ‎2023-03-07 12:38 AM
Hi There @APC_Matt
i had this issue some time ago with having an ! in the credentials, but no one replied with a way to reset the unit
is there a way to get a recovery key
Model: HS-500
SN: AB0443140538
Haywardi_apc
Crewman Haywardi_apc
Crewman
Posted: ‎2023-03-07 01:50 AM
2732
Hi there,
I have lost the login details as well.
Unit details are:
Model HS-500
Serial: AB0846823158
Haywardi_apc
Crewman
Posted: ‎2023-03-07 01:58 AM
In response to Haywardi_apc
WOW, seriously impressive, thank you Matt
Falcon
Falcon
Cadet
Posted: ‎2023-04-19 11:43 AM
Same problem:
SN: AB1026816940
funpager
funpager
Cadet
Posted: ‎2023-10-01 07:00 AM
I have the same problem!
Can someone send me the backdoor credentials?
  Serial number: AB2319812098
  Firmware revision: l1
  Web firmware revision: l6
  UPS date of manufacture (mm-dd-yyyy): 05-11-2023
  Battery replacement date (mm-dd-yyyy): 05-11-2023
funpager2
funpager2
Cadet
Posted: ‎2023-10-01 11:23 PM
I have the same problem and need backdoor credentials:
Serial (Webinterface) AB2319812098
APC_Matt
Lieutenant JG
Posted: ‎2023-10-09 07:01 AM
2376
@funpager2 Can you enable Private Messaging in your profile so I can send you the password.  Thanks  Matt
Hub
Crewman Hub
Crewman
Posted: ‎2023-10-09 07:11 AM
Hello Matt, I enabled all private function. Thank you, Hubert
funpager2
funpager2
Cadet
Posted: ‎2023-10-09 10:28 PM
@APC_Matt thank you for your reply!
i do not find where to enable private messaging?
can you see my e-mail from my profile or can you give me a hint where to enable PM?
funpager
funpager
Cadet
Posted: ‎2024-04-02 04:17 AM
@Hub
I did not received the private message with new admin credentials for the hs500
could you send it again please?
MiG007
MiG007
Cadet
Posted: ‎2024-08-28 10:54 AM
I tried to do the reset on my APC Back-UPS HS 500 because network login would accept user and password. Can I get new admin credentials?
Serial number: AB0733821274
g_m_k
g_m_k
Cadet
Posted: ‎2024-10-02 09:15 AM
@APC_Matt Can you please help with my unit? 🙂
Serial number: AB0932291243
medwedos
medwedos
Cadet
Posted: ‎2024-11-13 09:29 AM
Same login problem, please help...
Serial number: AB1308805265
Web firmware revision: l5
ixn
ixn
Cadet
Posted: ‎2024-11-26 11:54 AM
1604
@APC_Matt We're also locked out of one of our UPS'. Can you please assist getting back in? Thank you.
Model
Smart-UPS SRT 3000
Serial Number
AS1913195998
Firmware Revision
UPS 06.2 (ID1010)
APC_Matt
Lieutenant JG
Posted: ‎2024-11-28 12:24 AM
In response to ixn
Hi Ixn
If you're locked out of the UPS's network management card we have an FAQ giving the password reset procedures
https://www.se.com/ie/en/faqs/FA156075/
Regards
Matt
BJMAC
BJMAC
Cadet
Posted: ‎2024-12-27 01:58 PM
Matt:
I have the same issue - need a password reset:
  Serial number: AB1038827944
Thanks so much!
Brian
Falcon
Falcon
Cadet
Posted: ‎2025-08-27 10:49 AM
Same problem:
SN: AB0851826994
Thanks!
Falcon
Falcon
Cadet
Posted: ‎2025-08-31 07:23 AM
Same problem:
SN: AB1527813582
Thanks!
Anon_User674
Anon_User674
Cadet
Posted: ‎2025-11-27 03:09 AM
Hello, I have experienced the same problem on both of my HS-500inets
Serial number: AB0549142677
Serial number: AB0549242629
Thanks in advance.
  • « Previous
    • 1
    • 4
    • 5
    • 6
  • Next »
