Posted: 2021-06-28 12:48 AM . Last Modified: 2024-03-27 03:47 AM
I logged into the unit via the web interface with the default username of "apc" and default password of "apc". Used IE of course since Firefox isn't supported.
I went and tried to change the username and password. I used a complicated password that had capital letters and an Exclaimation point "!" in it. And I change the username to "admin". I hit ok and it said are you sure, and I said "yes". Now I can't log in. It is like it scrambled my password. I'm 100% sure I know the password, and since the password box didn't obfuscate it, I know i didn't misstype it when I originally typed it in.
I tried popping the front cover off of the unit and doing a manual reset with a paperclip. I did that while the unit was turned on, with the unit turned off, and even with the unit unplugged. Tried it for 5 seconds like the manual says, even tried for up to 30 seconds. Tried holding it while powering it off, unplugging, and powering on. Nothing works. When I try to log back in with the original username/password of apc/apc, it won't take it.
What can I do? Is this defective and do I need to return the unit to the place of purchase? Is there another way I can reset the password? maybe some other utility I can run?
Thanks in advance!
Dave
Posted: 2021-06-28 01:19 AM . Last Modified: 2024-03-27 03:36 AM
Hi Clarkson,
can you please help me generate a backdoor password for my APC Back-UPS HS 500 UPS? I managed to block it by changing the password.
The serial number is AB0549143284
please reply directly on my private email address.
Thanks a mill in advance,
Mihai
Hey jplf,
We really sorry for the inconvenience caused.
Try the following login credentials and see if that works fine.
User name: 2040508F902228
Password: 2040508F902228
If this does not work, I recommend you to reset the UPS to factory defaults and then try accessing the UPS. To reset the Back-UPS HS to factory default values, use the UPS Settings button. If the Back-UPS HS does not reset using the software, remove the Battery Cover and insert a small object (about 2 inches in length) into the hole located next to the telephone jack (refer the UPS user manual-Figure 12) for approximately 5 seconds. Note: The telephone jack is provided for factory testing only - do not connect anything to this jack).
I hope that this helps. Please let me know if you have any question.
Have a nice day 🙂
Posted: 2021-06-28 01:20 AM . Last Modified: 2024-03-27 03:36 AM
Independis,
I've sent a PM message that contains your login credentials.
Techie beat me to it. 😛 Glad you're up and running again though!
Mr. P,
I also am locked out of my APC BH500NET. (Back-UPS HS 500)
So glad there is a solution for this finally!
Serial Number is 3B0951X02
Thanks very much in advance!
Buzz, Techie
Unit is still running fine- and hopefully with a few more years service in it.
Once again, many thanks for provding a solution. 🙂
bradleybaldwin1 can you provide the correct S/N of your unit. There should be a total of 12 characters on the S/N.
A PM has been sent to your Inbox brad
Hi, guys.
I have same problem with my HS 500. Serial is 5B0745T28647.
Posted: 2021-06-28 01:21 AM . Last Modified: 2024-03-27 03:36 AM
Hello, please help with your password
Model:BH500INET
SN: 5B0752T06713
Posted: 2021-06-28 01:21 AM . Last Modified: 2024-03-27 03:35 AM
Please send the backdoor credentials. Used a password with !.
APC Back-UPS HS 500
Serial number: AB0803807412
Model:BH500INET
SN: 3B1207X09746
Same thing here. Please send backdoor password.
Model: APC Back-UPS HS 500
Serial number: AB1028808439
Thanks-
Sean
Message was edited by: seanriddle
Oops... left off the last few digits by mistake... should be 3B0951X02696.
Thanks!
all, i apologize for the delay. private messaging is not working properly on the forum which I am addressing. i'd like to note the quickest way (if you haven't already) to get a backdoor password would be to contact your local APC support (via phone or email).
Hi All,
For those of you who has been requesting for the backdoor password and do have an e-mail address setup on your profile, please check your Inbox. I've sent you your own personal login details.
Posted: 2021-06-28 01:22 AM . Last Modified: 2024-03-27 03:35 AM
Sir,
I'm guessing that the serial number on the sticker doesn't render the correct password on your end. Could you try the one listed on the web interface to generate a username/password?
It is
AB0951802696
Thanks in advance!
I have same problem with my HS 500. Serial number is 3B1123X14609.
thx
Having the same problem.
Serial# - 380951X07410
Thanks!
1
Message was edited by: NAM
Posted: 2021-06-28 01:23 AM . Last Modified: 2024-03-27 03:35 AM
Serial # AB1041854321
Thank you..
Hi Ryan,
I PM'ed you the login credentials that you need.
Could I ask you for some help as well? It is much appreciated!
My serial number is AB1027803341
Ralf
Same thing here.
Please send me password.
Serial number: AB0747839375
I have sent a direct message to you sonic13
Posted: 2021-06-28 01:23 AM . Last Modified: 2024-03-27 03:34 AM
Another PM has been sent to you bradleybaldwin1
Worked perfectly, sir!
Lesson learned... trust the serial number listed on the web interface, not the sticker ![]()
Thanks very much for your support!
Posted: 2021-06-28 01:24 AM . Last Modified: 2024-03-27 03:34 AM
I have the same problem...
SN is AB1025822468
can you help?
Serial number: AB0549142599
Thank You Very Much , Petr
Message was edited by: tsolomon
Same issue here
S/N: AB0920833124
Username and Password emailed to krislukas
Posted: 2021-06-28 01:25 AM . Last Modified: 2024-03-27 03:34 AM
A PM has been sent to nspasov@gftforex.com
hi sorry mine didnt work last time, can we try again, S/N is : AB1026803339
thanks very much
Luke
Dear Bala,
I've found your post after I running in the same issue.... 😞
On today I've changed the password using the "." and "!" char and now there are no way to enter in web console.
I've also tried to reset to factory using the software button and hardware button but without any succces.
Can you send me the backdoor password or, if any, an alternative method to regain access to the web console ?
Serial Number: AB1123821815
I am also locked out of our APC Back-UPS HS 500. Serial # is AB1043831307. Would really appreciate a back-door username/password to get us back in.
Thanks!
Hi Steve and Luca,
Our tech support is prepared to handle requests for the backdoor resets rather than us handling them publicly here. esupport@apc.com is a quick way. This thread is locked but actually allowed replies mistakenly. For anyone else with this issue, please contact your local support for a discrete way to receive a backdoor password for your BH500 product. Thanks!
Hello I also have an APC Back-UPS HS 500 and I did the default password which doesn't work.
The serial number is:
3B1130X49445
Thank you in advance
Hi Benny
I sent your log on details as a message
Regards
Matt
Posted: 2021-06-28 01:26 AM . Last Modified: 2024-03-27 03:34 AM
user/password you send my don't play
this is technical page:
Serial number: AB1130849445
Firmware revision: l1
Web firmware revision: l5
UPS date of manufacture (mm-dd-yyyy): 07-24-2011
Battery replacement date (mm-dd-yyyy): 07-24-2011
thanks
Hi
Sent in Direct message using the latest serial number you've given.
Matt
Same problem, I can not access the UPS as I do not have the password. Please can someone send them to me please:
Model: APC Back-IPS HS500
Serial Number: AB0846823158
Thanks in advance
Iain
Have the same problem, locked out and unable to access the interface.
Serial Number AB0846823158
Please help it's frustrating enough to be locked out from basic management functions, particularly when I wonder why someone viewed them necessary to protect.
Posted: 2021-06-28 01:26 AM . Last Modified: 2024-03-27 03:33 AM
Hi Iain
I sent the username and password via a direct message
Regards
Matt
Hi Matt,
Thanks for getting back to me.
Not sure how I get this direct message. Nothing has arrived via my email and there is no option on my account for "Direct Messages". Please advise.
Hi Matt,
Thank you, message appeared in my email. Much appreciated.
Posted: 2021-11-17 06:47 AM
oh boy, seems I am a victim too... used a $ in my pw.
Is there a list of chars not allowed please?
Could I get a backdoor pw for my unit? AB1408801257
Many Thanks
Posted: 2022-03-13 01:22 AM
Hi There Clarkson and SE support
i found this thread and have the same issue, can i get my work around password please
details of my unit are S/N AB0443140538
Posted: 2022-03-14 07:15 AM
Hi Damien
I've sent you the username and password as a direct message
Regards
Matt
