Posted: 2021-06-28 12:48 AM . Last Modified: 2024-03-27 03:47 AM
I logged into the unit via the web interface with the default username of "apc" and default password of "apc". Used IE of course since Firefox isn't supported.
I went and tried to change the username and password. I used a complicated password that had capital letters and an Exclaimation point "!" in it. And I change the username to "admin". I hit ok and it said are you sure, and I said "yes". Now I can't log in. It is like it scrambled my password. I'm 100% sure I know the password, and since the password box didn't obfuscate it, I know i didn't misstype it when I originally typed it in.
I tried popping the front cover off of the unit and doing a manual reset with a paperclip. I did that while the unit was turned on, with the unit turned off, and even with the unit unplugged. Tried it for 5 seconds like the manual says, even tried for up to 30 seconds. Tried holding it while powering it off, unplugging, and powering on. Nothing works. When I try to log back in with the original username/password of apc/apc, it won't take it.
What can I do? Is this defective and do I need to return the unit to the place of purchase? Is there another way I can reset the password? maybe some other utility I can run?
Thanks in advance!
Dave
Posted: 2021-06-28 12:57 AM . Last Modified: 2024-03-27 03:44 AM
Unfortunately I did not get any PM. Could you send it again?
Kindly PM me which username are you using and the serial number.
My SN is 3B1041X54301. Please send me information to tkski@o2.pl or ntrtom@gmail.com
A PM has been sent to afarnakeev.
A PM has been sent to tkski@o2.pl.
Same, please PM backdoor: #AB1014851877
Having the same problem:
MAC Address: 00.C0.B7.24.07.40
Technical Parameters
Model: APC Back-UPS HS 500
Serial number: AB1123845510
Please assist
Yeah, I'm still pretty disappointed. I expected way better from APC.
Contact support directly and they will give you a way to access the device again. I'm sure they don't want it shared on the forum.
Dave
Can confirm the problem with the HS 500. If you use an exclamation mark in the password, you can no longer a) login and b) the system reset button has no effect in clearing it. Also, brain-deading the unit does not clear the problem - ie there is no reset to the default user id and password. As others have said, this is a potentially great product with a pretty basic problem and it's surprising that there's no firmware update planned or available.
Posted: 2021-06-28 12:58 AM . Last Modified: 2024-03-27 03:44 AM
Yeah, the ONLY option is the backdoor password given. The password/system reset buttons DO NOT WORK when the password has been set to an "invalid password".
I tried for hours before contacting support and being given the backdoor access.
Oh well, probably time to dump the unit. The only solution offered by APC support - after 3 business days! - is to reinstall the BackUPS HS software. So I did. Launched the BackUPS HS software, clicked on "UPS Settings" button. And no difference (not that I expected any). Still can't login to the unit using the default username and password.
Seems like some parts of APC support don't support this model - probably too low-end.
I have the same problem as some others in this thread and need a password for my device:
Serial number: AB0606340221
Still no new firmware in sight for HS 500?
I have:
Firmware revision: l1
Web firmware revision: l4
Thanks in advance!
Posted: 2021-06-28 12:58 AM . Last Modified: 2024-03-27 03:43 AM
Credentials has been sent thru PM
Also can't login anymore,
My serial number is 3B1025X23015
APC HS-500
Thanks but it doesn't work.. =(
where u guys generate these credentials?
I have the same problem...
SN is AB0509141607
can you help?
Clarkson,
thank you very much! It works now!
I was able to change my pass to less complex one.
Best wishes!!
I sent you a private message - try those.
Posted: 2021-06-28 12:59 AM . Last Modified: 2024-03-27 03:43 AM
Hi Andre your login credentials has been sent thru PM.
Also have this problem in the Netherlands.
Would like to receive a solusion for this error please.
Sr. nr. 3B 10 25 X2 29 99
MAC your credentials has been sent.
I copied and pasted the new username and password, but it did not work.
Manual reset does also not work, You can't do anything wrong
what to do next?
Sr.nr 3B1025X22999
same problem here
serial AB0551240385
thanks
Help!
I'm also locked out of a BH500NET after specifying a complex password. Serial #: AB1130836611
Cheers!
Same Issue 3B1105X27487
thank you it works
I have the same situation. Could you generate the code for me? Serial number is AB0919800858.
PM has been sent to matejovic.
Posted: 2021-06-28 01:00 AM . Last Modified: 2024-03-27 03:43 AM
Hi Techie,
Have the same issue on TWO... yep TWO units !!!
Now I know my password is a bad one to use and it is not my brain geting fried !! lol
Could you get the password reset for
SN 3B1038X37601
AND
SN 3B1038X37383
Thanks a million...
Gareth
Same problem here. Tried the software and hardware reset methods and neither works.
Serial number: AB0509141440
Radek
Posted: 2021-06-28 01:00 AM . Last Modified: 2024-03-27 03:42 AM
SN: AB0845834387
Thanks!
Serial #4B1003290661
Andy
Have the same password problem with my APC.
Serial: AB0930291065
Can you help me?
Hello , I have the same problem. Reset don't help. My serial number is 3B0926X39813.
Thanks.
Oltas
A PM has been sent to Olaf.
Posted: 2021-06-28 01:01 AM . Last Modified: 2024-03-27 03:42 AM
I have the same password problem...
SN: AB0551260078 on APC Back-UPS HS 500....
This device has been working great for ~3years. Thanks
-Bob O
Same here - Serial # AB0549340265
Thank you...
hi there,
i have the same problem, serial number (seems to be) 3B1041X54330
Thanks for the fast answer.
But it did not help. The webinterface of the unit shows the serial number AB0926839813 which ist quite different from the one on the unit and the quality assurance test 3B0926X39813. Which one is the right for the backdoor?
Thanks Oltas
Message was edited by: Olaf
Hallo,
the message above don't show my text.
The Username Password in the PM don't work on my BH500 I NET. But the webinterface shows the serial number AB0926839813. On the unit and on the quality assurance test is the 3B0926X39813.
Oltas
Olaf, I sent you another Username and Password credentials thru PM.
Posted: 2021-06-28 01:02 AM . Last Modified: 2024-03-27 03:42 AM
I have some problems with login sent to my UPS. I used UID and PWD sent to me but it doesn't work. I tried to reset to factory default values using Manual Reset acording to the User's Manual but it doesn't work too. I assigned a name to my UPS. Should it be reset when I reset to factory values Is there any other way to check why I can't change this settings?
Not sure if this thread is still active, but I need my password reset as well. My serial number is: AB1125809490
Thanks in advance.
need password for
SN AB0820834654
Message was edited by: akh1
Same problem.. S/N AB0438240641
Credentials has been sent to mustangman and akh1 thru PM.
A PM has been sent to shawkins
Posted: 2021-06-28 01:03 AM . Last Modified: 2024-03-27 03:42 AM
Same problem.. S/N AB1026803304 and AB0745824248
Thanks.
PM sent to FJK.
Posted: 2021-06-28 01:03 AM . Last Modified: 2024-03-27 03:41 AM
One more with same problem.
SN:AB0549246921 and SN:AB0549246924
Thanks.
