User Roles or User Group Roles (User or User Group Information tab)
User and device group access
Send InviteCancel
Select the role you want to assign to a local or remote user or user group.
Note
For a non-Data Center Expert Administrator user, including a user for which no role is selected, access privileges are determined by Device Group Access settings in the Users tab for that user, and for the user groups to which the user is assigned.
Role
Description
Full access to all server, monitoring, and surveillance functions for all device groups.
Note
The Data Center Expert Proxy is included automatically when the Data Center Expert Administrator role is selected.
Telnet access from the Data Center Expert server's public network to devices on its private network. Provides no access to server, monitoring, or surveillance functions, except as defined by other settings:
Local Users: User Group Memberships tab, and Device Group Access settings in the Users tab
Remote Users: Device Group Access settings in the Users tab
Local or Remote User groups: Device Group Access settings in the Users tab
Note
Before a Data Center Expert Proxy user can use Telnet to access a private-side device, Telnet must be enabled at that device, and SOCKS Proxy, a Server Access option for Server Administration Settings in the System menu, must be enabled.
