Monitoring access
User and device group access
Send InviteCancel
Five selections are available for user or user group monitoring access at a selected device group.
Note
Users assigned the Data Center Expert Administrator role, or assigned to a user group that has this role, have full monitoring and surveillance access, as well as access to all server functions.
Monitoring Access
Description
No Access
No monitoring access is provided.
View Access - No Camera Images
A user with this access setting for a device group can perform the following functions for the devices in that group:
View information about active and historical alarms.
View information about device sensors.
Create a Graph view for a selected sensor type that is associated with the devices.
View and export copies of saved reports in a table (as .csv or .txt file) or graph (as .bmp, jpg, or .png file) format.
Create and export copies of device sensor reports in a table (as .csv or .txt file) or graph (as .bmp, jpg, or .png file) format.
Launch to the web interfaces at the devices.
Request that the Data Center Expert server scan a selected SNMP or Modbus device, or set of SNMP and Modbus devices, to update the available information.
View Access
View NetBotz Appliance camera images.
View clips in active and historical alarms.
Create and export copies of device sensor reports in a table (as.csv or.txt file) or graph (as .bmp, jpg, or .png file) format.
View and Control Access
Users with this access setting for a device group can perform the same monitoring functions View Access provides, as well as the following additional functions:
Change the state of a sensor in the right-click menu of the "View Device Sensors" display, when available.
Change the state of an outlet in the "Outlet Control" display, when available.
Administration Access
A user with this access setting at a device group can perform all the same monitoring functions View Access provides, as well as the following additional functions:
Create a custom Map View for the device group.
Configure NetBotz Appliance Alert Thresholds and SNMP and Modbus Thresholds for device sensors in that group.
Configure NetBotz Appliance Configuration options at monitored NetBotz Appliances in that group.
Configure the Device Configuration settings for SNMP and Modbus devices in that group.
Configure the Device File Transfer Settings.
Apply SNMP device and NetBotz Appliance firmware updates that have been downloaded to the Data Center Expert server for the group's devices.
Note
Only a Data Center Expert Administrator can download the updates to the server.
