Modify Device Group Access display
User and device group access
  • EcoStruxure IT Help Center
  • DCE server administration settings
  • User and device group access
  • Modify Device Group Access display
  • Mark as Read
  • User Group Memberships tab
  • User Group Members tab
  • User Credentials (User Information tab)
  • Managing authentication servers, remote users, and...
  • Managing a remote user group
  • Managing a local user group
  • Device Group Access (Users tab)
  • Monitoring access
  • Authentication Servers tab
  • Users and User Group details
  • User Roles or User Group Roles (User or User Group...
  • Monitoring access
EcoStruxure IT Support
Request Support
Back to User and device group access
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:12 AM
Define the Monitoring Access and Surveillance Access you want a user or user group to have for the device group selected in the Device Group Access settings section of the Users tab.
The access settings defined for one device group can affect the settings available to other device groups.
  • All settings are available for All Devices, unless another device group has had settings added (check-marked in the Device Group Access settings list): no setting above the highest setting selected at any other group is available for the All Devices group. For example:
    • If a device group has had a setting set to View Access, and no device group has a higher setting selected, only the View Access and No Access settings will be available for the All Devices group.
    • If any device group has had its Monitoring Access set at View and Control Access, Administration Access will be unavailable for that monitoring access for the All Devices group.
      Note
      If any group other than Unassigned has had access set at Administration Access, all settings for that monitoring access will be available for the All Devices group.
  • The settings available at other groups depend on the settings defined at their parent group: settings more restrictive than the parent group's settings (All Devices, or the group to which a subgroup is assigned) are unavailable. For example:
    When All Devices has View Access selected for its Device Access, and View and Tag Access selected for its Surveillance Access, No Access is unavailable for the Monitoring Access at all other groups, and No Access and View Access are unavailable for the Surveillance Access at all other groups.
Another factor affects the access set at device groups other than All Devices: you can select an access that is identical to the access a group is inheriting from All Devices, or a parent group. Although the selected group's access settings remain unchanged, those access settings are no longer inherited, and can no longer be affected by changes made to inherited settings. For example, if you select View Access, instead of View Access (Inherited from All Devices), the access selection will not be affected by changes to the All Devices group access selection.
