User Group Memberships tab
User and device group access
Send InviteCancel
Use this tab to select the user groups to which you want to assign a local user.
Note
Local users cannot be added to remote user groups; remote users cannot be added to any user group, local or remote.
This tab lists all local user groups, allowing you to select the groups to which a local user is assigned. Three of those user groups are provided, by default.
Note
The user will be listed under any user group in the "Users and Device Group Access display's Users tab to which it is assigned in its User Group Memberships tab.
Device Administrators: by default, this user group provides Administration Access for monitoring, and No Access for surveillance, at all device groups.
Device Viewers: by default, this user group provides View Access for monitoring, and No Access for surveillance, at all device groups.
Server Administrators: by default, this user group provides the same access as theData Center ExpertAdministrator user role: full access to all server, monitoring, and surveillance functions.
Note
You can edit the default names and access privileges for any of these user groups.
