Users and User Group details
User and device group access
  • EcoStruxure IT Help Center
  • DCE server administration settings
  • User and device group access
  • Users and User Group details
  • Mark as Read
  • User Group Memberships tab
  • User Group Members tab
  • User Credentials (User Information tab)
  • Modify Device Group Access display
  • Managing authentication servers, remote users, and...
  • Managing a remote user group
  • Managing a local user group
  • Device Group Access (Users tab)
  • Monitoring access
  • Authentication Servers tab
  • User Roles or User Group Roles (User or User Group...
  • Monitoring access
EcoStruxure IT Support
Request Support
Back to User and device group access
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:12 AM
Use this section in the Users and Device Group Access display Users tab to manage the users and user groups that can access the server.
Information about the users and user groups is provided in a table:
Column Description
User or User Group Name Lists the user groups, including default (Device Administrators, Device Viewers, Server Administrators, and Unassigned Users) and user-created groups. Users are listed under the user group to which they are assigned (local users not assigned to another group are listed under Unassigned Users; remote users are listed only under Remote Users).
Note
This column is used in the Device Group Access section of the Users tab, as well.
Full Name Identifies the full name for a local user only, when defined in its "User Configuration" display.
Type Identifies each user or user group by its specific type.
Local User
Remote User
Local User Group
Remote User Group
Unassigned Users Group
Remote Users Group
Data Center Expert Administrator Identifies whether a user or user group is assigned the Data Center Expert Administrator role, and, thus, has full access to all server features and functions (Yes or No).
You use buttons or right-click options to add new local users or local user groups, and to edit or delete users or user groups, whether local or remote.
Note
Remote users and user groups are added using the "Users and Device Group Access" display Authentication Servers tab.
  • Add a local user using the "User Configuration" display (Add User button or right-click option).
    Note
    You can select right-click and local device group and click Add User to Selected Group to add a new user directly to the selected group (this option is unavailable when a remote user group is selected).
  • Add a local user group using the "User Group Configuration" display (Add User Group button or right-click option).
  • Edit the credentials, user roles, and user group membership for a selected local user using the "User Configuration" display (Edit button or right-click option).
  • Edit the name, user group roles, and user group members for a selected local user group using the "User Group Configuration" display (Edit button or right-click option).
    Note
    You cannot edit the Unassigned Users group, a group that lists local users that are not assigned to another local user group.
  • Edit the user roles for a selected remote user using the "User Configuration" display (Edit button or right-click option).
  • Edit the user group roles for a selected remote user group using the "User Group Configuration" display (Edit button or right-click option).
    Note
    You cannot edit the Remote Users group, listed in the table only when at least one authentication server has been added using the Authentication Servers tab.
  • Delete a local or remote user or user group (Delete button or right-click option).
    Note
    You cannot delete the Remote Users group, listed in the table only when at least one authentication server has been added, or the Unassigned Users group, which is always listed.
  • Access the Device Group Access section of the Users Tab (Device Group Access button or right-click option).
