Managing authentication servers, remote users, and remote user groups
User and device group access
Send InviteCancel
You use the "Add Authentication Server" or "Edit Authentication Server" wizard to add remote users and user groups that will have access to the console, depending on whether the authentication server that lists those users and user groups is included in the Authentication Servers tab.
Note
Use the Users tab to edit or delete remote users, and the User Groups tab to edit or delete remote user groups that have access to the Data Center Expert console.
In the Authentication Servers tab for the Users and User Groups option, click Add Authentication Server to access the "Add Authentication Server" wizard, or select a listed server and click Edit Authentication Server to access the "Edit Authentication Server" wizard.
To delete an authentication server, select that server in the Authentication Servers tab and click Delete.
In the OpenLDAP/Active Directory Server Settings display, configure the settings, if necessary, and click Next.
In the OpenLDAP/Active Directory Bind Settings display, configure the settings, if necessary, and click Next.
Identify a search base to narrow the search scope and decrease directory lookup time at the authentication server.
In the Remote Users and User Groups Selection display, select the users and user groups you want to add that will have access to the console.
