  • Industrial Automation
  • Solutions for Motor Management
  • Mark all as New
  • Mark all as Read
  • Float this item to the top
  • Invite a Friend
  • Threaded format
  • Linear Format
  • Sort by Topic Start Date
The message you are trying to access is permanently deleted.
Top Labels
Top Labels
  • Alphabetical
  • Low Voltage AC Drives 43
  • Drives & Motor Control 40
  • Design & Build 26
  • Products 24
  • Selection & sizing 22
  • Medium Voltage AC Drives 18
  • Training & How to 14
  • Digitalization 13
  • Energy Efficiency 12
  • Power Quality 12
  • Best Practice 9
  • Soft Starters 9
  • Contactors & Motor Starters 4
  • Material Handling 3
  • Technical Support and Troubleshooting 3
  • Connectivity 2
  • Safety 2
  • Smart Design & Engineering 2
  • Robotics 1
  • Previous
  • 1 of 2
  • Next
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Thumbnail of Altivar Process (Low Voltage)
22
Thumbnail of Altivar Process (Medium Voltage)
18
Thumbnail of Altivar Machine
Altivar Machine
13
Load more
  • All
  • Solved
  • Unsolved
  • Unanswered
Mahmoud201
Mahmoud201
Checking for an alternative to the product
What is replacement for VW3A3407 incremental encoder card of Altivar 71 substituted by Altivar ATV930?
Industrial Automation icon_circle Solutions for Motor Management
42 0 0
2025-12-01
PrashantCPatange
PrashantCPatange Cadet
ATV6000 Cell Bypass Voltage availability
In case of ATV6000, during cell bypass operation, what will be the % voltage available at the output of drive with various nos. of cell bypass condition? E.g with 1 cell bypass, 2 cell bypass, 3 cell b...
539 0 3
Latest Reply: Eng.Ehab
JohnShi
Crewman JohnShi Crewman
Common mode filters for ATV630/930 size 7
Hi, does anyone know why ATV630/930 size 7 (200~315kW) have no common mode filters option in catalogue? A customer required, and I think the common mode current shall be large in this level motor too.....
222 0 1
Latest Reply: JohnShi
Andrej1407
Andrej1407
Altivar atv320 AI1
Hi, can anyone please help me. I installed new ATV320U07N4C and have a problem because it is ignoring AI1 signal. I checked voltage and that is ok. How can that be fixed? The ATV has a small display an...
183 0 2
Latest Reply: Andrej1407
aditya.joshi
Crewman aditya.joshi Crewman
Schneider Electric: Powering the Future of Waste Management.
🌍As the world faces mounting environmental challenges, Schneider Electric is proud to lead the charge in transforming waste management through innovation & digitization.🌱Facts & Trends🌍 Over...
663 3 1
Latest Reply: PriscilaCunha22
Sabitovir
Sabitovir
Frequency Converter P’Drive mxPRO 4V500 facing E37 fault
Fault E37 “Safe Standstill” on P’Drive mxPRO 4V500 Hello, I am having an issue with my drive P’Drive mxPRO 4V500. The fault E37 – Safe Standstill appears immediately after the RUN command is given.The ...
185 0 0
2025-10-23
Simon_P
Simon_P
Apply an 4-20mA input to multi Atv630
Hello all, I have a question on how to wiring the pressure transmitter (XMLR010G1P25) 4-20mA analog signal to 2 VSD (ATV630) I connect the 4-20mA signal to the First VSD AI3 terminal and the COM termin...
639 0 3
Latest Reply: Hennie_Smith
MarPan
MarPan
ATV610 PID control PT1000
Hello. I have a hydraulic system for filling a domestic hot water tank from a heat recovery system. The system consists of a pump controlled by an ATV610 in HMI mode. I would like to automate the syste...
306 0 1
Latest Reply: Bastian_Schmitz
m_c
m_c
Multiple ATV320 on Modbus RTU
Hi, Is it possible to daisy chain multiple ATV320 on Modbus RTU using embedded RJ45 connection? If so, what is best practice? Thanks
305 0 1
Latest Reply: LucaFratini
jonathan.graves
jonathan.graves
Direct Replacement for LC1D40
Looking for direct replacement. Pics attached. Thank you
480 0 1
Latest Reply: L.Nauta
Shinekhuu
Shinekhuu
Soft starter
I want to size a soft starter to following freezer. Single phase, 660W, 110VStarting current 45A I was wondering if I can use 25A single phase ATS01 starter. Soft starter:https://www.se.com/jp/ja/prod...
967 0 3
Latest Reply: BrownSugar
  • « Previous
    • 1
    • 2
    • 3
    • 22
  • Next »
