ATV610 PID control PT1000
  • Industrial Automation
  • Solutions for Motor Management
  • ATV610 PID control PT1000
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
MarPan
MarPan
Cadet
Posted: ‎2025-10-06 03:30 AM
292
Hello.
I have a hydraulic system for filling a domestic hot water tank from a heat recovery system. The system consists of a pump controlled by an ATV610 in HMI mode. I would like to automate the system using a PID controller controlled by a frequency converter, controlled by measuring the temperature with a PT1000 contact sensor placed on the pipe supplying the recovered water to the tank.
I have the PT1000 sensor connected to input AI2, set to [1PT3].
The 'PID feedback assign' parameter is set to [AI2]. The 'PID feedback -> Type of control [TOCT]' parameter is set to [OTHER].
Where should I set the '°C' unit and the setpoint the controller will strive for?
Best regards
Mariusz Panek
  • Drives & Motor Control
  • ATV610
Bastian_Schmitz
Admiral
Posted: ‎2025-10-13 10:21 PM
So far I see to configure °C as unit for the setpoint is not possible. As additional information the accuracy of temperatur probes on the driver are only +/-4K.
