Posted: 2025-09-25 01:54 PM
Is it possible to daisy chain multiple ATV320 on Modbus RTU using embedded RJ45 connection?
If so, what is best practice?
Posted: 2025-09-28 01:39 PM
Yes it is possible, the best solution is to use the VW3A8306TF03 "T" branch and the VW3A8306RC termination resistor
