Release Notes for Smart-UPS Ultra 5-20 kW Firmware v3.4.1.1
  • EcoStruxure IT Help Center
  • Network Management Cards
  • Network Management Card 3
  • Smart-UPS Ultra 5-20 kW
  • Release Notes for Smart-UPS Ultra 5-20 kW Firmware v3.4.1.1
  • Release Notes for Smart-UPS Ultra 5-20 kW Firmware...
NMC Support
Request Support
Back to Smart-UPS Ultra 5-20 kW
Lt. Commander SwathiNaidu Lt. Commander
‎2025-12-02 12:06 AM
Affected Revision Levels
Component  File Details
Smart-UPS Ultra 5-20 kW Application Windows:
snst_nmc3_sucan_3-4-1-1.exe
Linux & macOS:
snst_nmc3_sucan_3-4-1-1.tar.gz
UPS Application for Smart-UPS Ultra 5-20 kW.
To upgrade to firmware version 3.0 or later, the only supported method is the Secure NMC System (SNS) Tool, which can be downloaded from www.se.com/secure-nmc or by searching for SFNMC3FMTSUCAN. To access the firmware in the software, a valid Secure NMC subscription is required. For more information, see the SNS Tool User Guide.
SwathiNaidu_0-1718792359613.pngIf you downgrade from firmware version 2.4+ to a firmware version lower than 2.4, this will cause the card to be formatted, erasing all security certificates, encryption keys, configuration settings, and the event and data logs.
New Features
New Feature
There is no new feature in this release.
Fixed Issues
Fixed Issue
UPS Family
SRTL
Devices
SRYL Devices
There is no fixed issue in this release.
Security Update
The following security vulnerabilities have been addressed in this release:
  • CWE-1286: Improper Validation of Syntactic Correctness of Input
  • CWE-787: Out-of-bounds Write
  • CWE-120: Buffer Copy without Checking Size of Input
Known Issues
Known Issue UPS Family
SRTL
Devices
SRYL
Devices
After updating the NMC’s firmware via a USB flash drive, the USB is not recognized in the display or NMC Web UI.
Some pages in the Web UI help are not updated.
It can take up to 30 minutes to complete a UPS firmware upgrade when using HTTPS. To workaround this, use SCP as an alternative.
When a UPS firmware upgrade is in progress, the upsAdvcontrolFirmwareUpdate SNMP OID incorrectly reports the value as “noFirmwareUpdate” instead of “UpdateinProgress”.
Filtering by time does not work for the Power Event Log.
Entering unsupported commands in the Command Line Interface (CLI) does not return a E102 Parameter error.
You cannot unzip the debug file completely from a USB drive. This issue is seen intermittently.
You are unable to configure upsAdvConfigAlarmRedundancy OID from SNMP interface.
When an internal or external Battery Module is connected or disconnected from its slot, the Event Log entry does not report its serial number.
You cannot make configuration changes via the display when RADIUS is enabled and the User Mode is set to “Authentication Needed”.
The option to cancel or mute a UPS audible alarm is not present in the Web UI.
The ups -s start CLI command is unsuccessful even when the self-test is started correctly.
There is no option to set the language of the display in the NMC Web UI.
You cannot modify the output voltage setting from the SNMP interface if the output is in Manual Bypass.
Secure NMC System (SNS) Tool for Smart-UPS Ultra Hash Signatures
Windows
Signatures
CRC32
7CDE6EAF
CRC64
A8602CE45818F0D9
SHA-256
34C6BE2F17A879C4B5C1E3045F44CFEF87296361C76680DB581E540295D366F1
SHA-1
75E76A09E31A5ED3588A77A067A80711B734A511
BLAKE2sp
34667FD5A7A8C6E87C3DEECC155AC467792955BBF92AD7D4276D0A794E6EE1C3
Linux
Signatures
CRC32
F3AC9DC1
CRC64
59DF657A598ABCD6
SHA-256
1A3243A13CC41A29E31E1C5D4A06A2C7ACD0E944E894C3317F6CE69BC50E49BC
SHA-1
9208D793CFD7B9E5757C1BBE81FC29CDADB10702
BLAKE2sp
C3F1E30EBEDDE07744EB51FE5BE8E89A1CA8E1E45752C1FB91F236C2A3E73E50
macOS
Signatures
CRC32
7A531A64
CRC64
1EF057C1C39F9B0B
SHA-256
7DADF6AB7317BE123772E9E5267205D73B7C7E4A24FC3544E86364AC98CFBA98
SHA-1
FF0E2F116C1083E057B5C9061C77981E302A2A92
BLAKE2sp
DE2576ED012318F6AA5889A2EF44FF299F3FC24B87060A094E0A4D249733986D
