Release Notes for Smart-UPS Ultra 5-20 kW Firmware v3.0.1.4
  • EcoStruxure IT Help Center
  • Network Management Cards
  • Network Management Card 3
  • Smart-UPS Ultra 5-20 kW
  • Release Notes for Smart-UPS Ultra 5-20 kW Firmware v3.0.1.4
NMC Support
Request Support
Back to Smart-UPS Ultra 5-20 kW
Commander CDiggin Commander
‎2024-06-13 08:21 AM
on ‎2024-06-13 08:21 AM
Affected Revision Levels
Component  File Details
Smart-UPS Ultra Application apc_hw21_sucan_3-0-1-4.nmc3 UPS Application for Smart-UPS Ultra 5-20 kW.
For details on upgrading the UPS Network Management Card 3 (NMC 3) firmware, see the NMC3 User Guide.
New Features
New Feature
UPS Family
SRTL Devices SRYL Devices
The NMC3 platform and Smart-UPS Ultra 5-20kW application are now IEC 62443-4-2 certified. ♦  ♦
Support added for audit logging to ensure control actions and configuration changes are recorded in the Event Log. ♦ ♦
Support added for remote authentication via the TACACS+ protocol. ♦ ♦
Security Update
Password security has been updated to align with the requirements for IEC 62443-4-2. By default, passwords now need to be a minimum of 8 characters in length (strong password setting enabled). ♦ ♦
Fixed Issues
Fixed Issue
UPS Family
SRTL
Devices
SRYL
Devices
The NMC3 Web UI now allows passwords with up to 64 characters, as expected.
For encrypted email settings, install CA certificate to the certificate store and set Require CA Root Certificate correctly.
Improved TLS certificate for email.
The NMC3 Web UI now allows the Battery Install date setting and other general UPS settings.
The correct On Battery status message will now appear on the Web UI Home page for Japanese.
The NMC now supports the latest set of UPS alarms with the correct severity and improved alarm messages.
Partially written files can now be recovered after a system reset event.
The Power Module Fault now appears correctly on the SNMP interface.
Improved Japanese translations for the display.
Able to set the OIDs
upsAdvConfigHighBypassLLTransferVolt
upsAdvConfigLowBypassLLTransferVolt from SNMP interface.
Security Update
The following security vulnerabilities have been addressed in this release:
  • CWE-74: Improper neutralization of special elements in output used by a downstream component (Injection).
  • CWE-79: Improper neutralization of input during web page generation (Cross-site Scripting).
Known Issues
Known Issue UPS Family
SRTL
Devices
SRYL
Devices
After updating the NMC’s firmware via a USB flash drive, the USB is not recognized in the display or NMC Web UI. ♦ ♦
Some pages in the Web UI help are not updated. ♦ ♦
It can take up to 30 minutes to complete a UPS firmware upgrade when using HTTPS. To workaround this, use SCP as an alternative. ♦ ♦
The alarm description is shown incorrectly in DCE for outlet group-related alarms. ♦
You cannot unzip the debug file completely from a USB drive. This issue is seen intermittently. ♦
When a UPS firmware upgrade is in progress, the upsAdvcontrolFirmwareUpdate SNMP OID incorrectly reports the value as “noFirmwareUpdate” instead of “UpdateinProgress”. ♦
Filtering by time does not work for the Power Event Log. ♦
Entering unsupported commands in the Command Line Interface (CLI) does not return a E102 Parameter error. ♦
You are unable to configure upsAdvConfigAlarmRedundancy OID from SNMP interface.   ♦
Only alphanumeric passwords are supported for new users created in the NMC for access to the display.   ♦
When an internal or external Battery Module is connected or disconnected from its slot, the Event Log entry does not report its serial number.   ♦
You cannot make configuration changes via the display when RADIUS is enabled and the User Mode is set to “Authentication Needed”.   ♦
The option to cancel or mute a UPS audible alarm is not present in the Web UI.   ♦
The ups -s start CLI command is unsuccessful even when the self-test is started correctly.   ♦
There is no option to set the language of the display in the NMC Web UI.   ♦
There is no option in the Web UI or the display to cancel a UPS audible alarm test. It is not recommended to initiate a continuous alarm as the only way to stop the UPS beeping is to turn off the UPS.   ♦
You cannot modify the output voltage setting from the SNMP interface if the output is in Manual Bypass.   ♦
The “Minimum Redundancy lost" event is not displayed in PowerChute Network Shutdown although it is supported by the NMC. If this event occurs, the server will not shutdown.   ♦
Secure NMC System (SNS) Tool for Smart-UPS Ultra Hash Signatures
Signatures snst_nmc3_sucan_3-0-1-4-v2.exe
CRC32 B912E432
CRC64 80C0307FA16E865B
SHA-256 DC256451913BE8FA1DCD63E3205DBEA012D83C4FA82E5610BEE2864F3CBD4C61
SHA-1 B03DB85215D2500EE3C71FB48714259557AD3173
BLAKE2sp A49568C6AA16E7BFDBD9E99F6FF9123AE5532FFB8D4304B2223631801ABA2C79
