Release Notes for Smart-UPS Ultra 5-20 kW Firmware v3.3.0.8
  • EcoStruxure IT Help Center
  • Network Management Cards
  • Network Management Card 3
  • Smart-UPS Ultra 5-20 kW
  • Release Notes for Smart-UPS Ultra 5-20 kW Firmware v3.3.0.8
NMC Support
Request Support
Back to Smart-UPS Ultra 5-20 kW
Lt. Commander SwathiNaidu Lt. Commander
‎2025-03-03 12:44 AM
Affected Revision Levels
Component  File Details
Smart-UPS Ultra 5-20 kW Application Windows:
snst_nmc3_sucan_3-3-0-8.exe
Linux & macOS:
snst_nmc3_sucan_3-3-0-8.tar.gz
UPS Application for Smart-UPS Ultra 5-20 kW.
To upgrade to firmware version 3.0 or later, the only supported method is the Secure NMC System (SNS) Tool, which can be downloaded from www.se.com/secure-nmc or by searching for SFNMC3FMTSUCAN. To access the firmware in the software, a valid Secure NMC subscription is required. For more information, see the SNS Tool User Guide.
SwathiNaidu_0-1718792359613.pngIf you downgrade from firmware version 2.4+ to a firmware version lower than 2.4, this will cause the card to be formatted, erasing all security certificates, encryption keys, configuration settings, and the event and data logs.
New Features
New Feature
UPS Family
SRTL Devices SRYL Devices
Command Line Interface (CLI) added to the Web UI under Control > Network > Web CLI.
IPv6 functionality is improved.
Added support for smart Service Bypass Unit.
The display now fully supports the lights/beeper test.
Added display support for Efficiency Test Mode.
Fixed Issues
Fixed Issue
UPS Family
SRTL
Devices
SRYL
Devices
The LDAP TLS connection now works as expected when connecting to an IP address and server certificate using SAN type "iPAddress".
DHCPv6 no longer intermittently reboots when the network interface starts or when the Ethernet cable is reseated.
Improved logging for account disabled events.
The expiration date of self-signed certificates has been updated.
You can now send emails as expected if the SMTP server uses an IPv6 address.
The severity of Syslog-related events in the configuration file has been corrected.
The NMC now supports the latest set of UPS alarms with the correct severity and improved alarm messages.
The alarm description is now shown correctly in DCE for outlet group-related alarms.
Security Update
The following third-party components (open source or proprietary) have been updated to address cybersecurity vulnerabilities:
  • RADIUS Protocol under RFC 2865 - CVE-2024-3596
Implemented support for the Message-Authenticator attribute.
The following security vulnerability has been addressed in this release:
  • CWE-1285: Improper Validation of Specified Index, Position, or Offset in Input
Fixed an improper user input validation.
Known Issues
Known Issue UPS Family
SRTL
Devices
SRYL
Devices
After updating the NMC’s firmware via a USB flash drive, the USB is not recognized in the display or NMC Web UI. ♦ ♦
Some pages in the Web UI help are not updated. ♦ ♦
It can take up to 30 minutes to complete a UPS firmware upgrade when using HTTPS. To workaround this, use SCP as an alternative. ♦ ♦
When a UPS firmware upgrade is in progress, the upsAdvcontrolFirmwareUpdate SNMP OID incorrectly reports the value as “noFirmwareUpdate” instead of “UpdateinProgress”. ♦ ♦
Filtering by time does not work for the Power Event Log. ♦ ♦
Entering unsupported commands in the Command Line Interface (CLI) does not return a E102 Parameter error. ♦ ♦
You cannot unzip the debug file completely from a USB drive. This issue is seen intermittently. ♦
You are unable to configure upsAdvConfigAlarmRedundancy OID from SNMP interface.   ♦
When an internal or external Battery Module is connected or disconnected from its slot, the Event Log entry does not report its serial number.   ♦
You cannot make configuration changes via the display when RADIUS is enabled and the User Mode is set to “Authentication Needed”.   ♦
The option to cancel or mute a UPS audible alarm is not present in the Web UI.   ♦
The ups -s start CLI command is unsuccessful even when the self-test is started correctly.   ♦
There is no option to set the language of the display in the NMC Web UI.   ♦
You cannot modify the output voltage setting from the SNMP interface if the output is in Manual Bypass.   ♦
Secure NMC System (SNS) Tool for Smart-UPS Ultra Hash Signatures
Windows
Signatures
CRC32
2287D7E8
CRC64
BD2BB46FE19880C7
SHA-256
784095DFECA1F011FBDC4AACF97D3EE311FEC20AD3794BD37597514248871E2D
SHA-1
95956FDC1D54E5A4161197D192362AE00F8542A5
BLAKE2sp
A7D04B3AE3432AA17751FDF8B785706692D993CBDCC27BEA775187610CADE644
Linux
Signatures
CRC32
DE3EAC04
CRC64
8A680C99FFFE53BE
SHA-256
7B3A42CC0E67C5C5E24B36CC65CD97F8823484DA07EFDBDCA269136E7787179C
SHA-1
52E868554F1200179BC907A7CE68B6B6C9739C33
BLAKE2sp
C70D6540D9B60E833A8E6D77036C75C50A97CF7804F6A0EF5A02068A219E6A02
macOS
Signatures
CRC32
428EB57D
CRC64
ABBA1AA4129247E0
SHA-256
A6A4DC96FCAB00B967B9906392E5237F798D84E0427EBBF84CBA1ED35F6D62FD
SHA-1
83ACC8A455C6922C217B54D42E1720CA9F6ABF81
BLAKE2sp
F6818C9DB6FA17D2D70AD9ECFC6A489F289D8E7A684482272B8E22E74E54E0FD
