Release Notes for Smart-UPS & 1-Phase Symmetra Firmware v3.4.1.1
Send InviteCancel
Windows: snst_nmc3_sy_3-4-1-1.exe Linux & macOS: snst_nmc3_sy_3-4-1-1.tar.gz
UPS Application for 1-Phase Symmetra, Symmetra LX.
To upgrade to firmware version 3.0 or later, the only supported method is the Secure NMC System (SNS) Tool, which can be downloaded fromwww.se.com/secure-nmcor by searching for SFNMC3FMTSU. To access the firmware in the software, a valid Secure NMC subscription is required. For more information, see theSNS Tool User Guide.
NOTE:If you upgrade to firmware version 2.0 or later, you cannot downgrade to a firmware version lower than 2.0.
If you downgrade from firmware version 2.4+ to a firmware version lower than 2.4, this will cause the card to be formatted, erasing all security certificates, encryption keys, configuration settings, and the event and data logs.
New Features
New Feature
There is no new feature introduced in this release.
Fixed Issues
Fixed Issue
UPS Family
Smart-UPS
1-Phase Symmetra
There is no fixed issue in this release.
Security Update
The following security vulnerabilities have been addressed in this release:
CWE-1286: Improper Validation of Syntactic Correctness of Input
CWE-787: Out-of-bounds Write
CWE-120: Buffer Copy without Checking Size of Input
