Release Notes for Smart-UPS & 1-Phase Symmetra Firmware v3.3.0.8
  • EcoStruxure IT Help Center
  • Network Management Cards
  • Network Management Card 3
  • Smart-UPS & 1-Phase Symmetra
  • Release Notes for Smart-UPS & 1-Phase Symmetra Firmware v3.3.0.8
NMC Support
Request Support
Back to Smart-UPS & 1-Phase Symmetra
Lt. Commander SwathiNaidu Lt. Commander
‎2025-03-03 12:07 AM
Affected Revision Levels
Component  File Details
Smart-UPS Application
Windows:
snst_nmc3_su_3-3-0-8.exe
Linux & macOS:
snst_nmc3_su_3-3-0-8.tar.gz
UPS Application for Smart-UPS, Smart-UPS RT, Smart-UPS VT, MGE Galaxy 3500.
Symmetra Application
Windows:
snst_nmc3_sy_3-3-0-8.exe
Linux & macOS:
snst_nmc3_sy_3-3-0-8.tar.gz
UPS Application for 1-Phase Symmetra, Symmetra LX.
To upgrade to firmware version 3.0 or later, the only supported method is the Secure NMC System (SNS) Tool, which can be downloaded from www.se.com/secure-nmc or by searching for SFNMC3FMTSU. To access the firmware in the software, a valid Secure NMC subscription is required. For more information, see the SNS Tool User Guide.
NOTE: If you upgrade to firmware version 2.0 or later, you cannot downgrade to a firmware version lower than 2.0.
SwathiNaidu_0-1718792359613.pngIf you downgrade from firmware version 2.4+ to a firmware version lower than 2.4, this will cause the card to be formatted, erasing all security certificates, encryption keys, configuration settings, and the event and data logs.
New Features
New Feature
UPS Family
Smart-UPS 1-Phase Symmetra
The NMC3 platform and Smart-UPS and 1-Phase Symmetra applications are now IEC 62443-4-2 SL2 certified; a higher level of certification than SL1 announced in October 2023.
Command Line Interface (CLI) added to the Web UI under
Control > Network > Web CLI.
Fixed Issues
Fixed Issue
UPS Family
Smart-UPS
1-Phase Symmetra
The LDAP TLS connection now works as expected when connecting to an IP address and server certificate using SAN type "iPAddress".
DHCPv6 no longer intermittently reboots when the network interface starts or when the Ethernet cable is reseated.
Improved logging for account disabled events.
The expiration date of self-signed certificates has been updated.
You can now send emails as expected if the SMTP server uses an IPv6 address.
The severity of Syslog-related events in the configuration file has been corrected.
SmartSlot NMC, with NTP enabled and a non-zero IPv4 address, is now allowed to set the UPS Last Battery Replacement Date when the embedded NMC does not have a network connection.
For UPS devices that do not have a valid serial number on their internal battery modules, the NMC will no longer show the serial number on the Web UI.
Security Update
The following third-party components (open source or proprietary) have been updated to address cybersecurity vulnerabilities:
  •  RADIUS Protocol under RFC 2865 - CVE-2024-3596
Implemented support for the Message-Authenticator attribute.
The following security vulnerability has been addressed in this release:
  •  CWE-1285: Improper Validation of Specified Index, Position, or Offset in Input
Fixed an improper user input validation.
Known Issues
Known Issue
There is no known issue in this release.
Hash Signatures
Windows
Signatures snst_nmc3_su_3-3-0-8.exe
CRC32
29F3F0A9
CRC64
27EECC865F1F2EC9
SHA-256
D625F26E44E0385A109079432D6F692871CE5FA962378C222159AC5334F1CD56
SHA-1
17FAEA0C8235B90BE52C27FA9E30A9390FDB83B6
BLAKE2sp
DF8183FFE1BA8D6418256FF3562991C2BFA80B3EBE7317DD65B4D5833375BA42
Signatures snst_nmc3_sy_3-3-0-8.exe
CRC32
8717AA00
CRC64
57CB1061F06F8C6B
SHA-256
A14F2D57C6822B0364525E19A1A8F764F4C03B44F3CB10631332B7665C2368A8
SHA-1
98683E86EAD544414A922597000598B21011B47D
BLAKE2sp
E6112CF93A7B80F65259881525C26F5E54C24D8F8A50E582064EE5A13EAAE455
Linux
Signatures snst_nmc3_su_3-3-0-8.tar.gz
CRC32
F9255B7B
CRC64
C99BACD067E0850C
SHA-256
09A68FD73E62959CB472178348D09FB01C58A0924F5321FD2C5634DF0B18140D
SHA-1
AB242A6FBB4A8F6271861F3E18AD45AAA1A19548
BLAKE2sp
CF8FF92739BCD7F36094F1A6BB1503DEF2F1654883A791796A52D2F921FA9C18
Signatures
CRC32
85192DE2
CRC64
4C5A84642CFF86E5
SHA-256
B074B8FC98B80B552CBFD1A4AA27FEDAF32AE2EE96E7E35DE840CEC63000AF62
SHA-1
2F95AB8AB3E085829E27F61859276C2A4317B0D9
BLAKE2sp
8598726B3D8048CB78D3A3DA3820765EE2A42B35AA3A3181B26FA8BB8AB36A94
macOS
Signatures
CRC32
AD6684B4
CRC64
3D3BDE289D776A84
SHA-256
A37C5F80E5189748294D667A7125C139778D7C026B64E3662BA6A109C4F73BDF
SHA-1
863AA7F1866B7CBC12D77E34ADACA54C7590FC1A
BLAKE2sp
47C036DBEA9FCFF831683AE603487C73431C902FA44510F4D8CA3D50A22DC781
Signatures
CRC32
3824F216
CRC64
86B354CD79925D05
SHA-256
B572975C0CF17817335033D4BF98562D96D53E9DBE96F4D92F695928E4C3C082
SHA-1
8D927310FB0D4C6A29BF38885954656A65770BD1
BLAKE2sp
9C4FFB105C93F9E589E8AE4E817465B560A5A387A88F22D625ADD8F3D06AEE9E
