Release Notes for Smart-UPS & 1-Phase Symmetra Firmware v3.4.0.8
  • EcoStruxure IT Help Center
  • Network Management Cards
  • Network Management Card 3
  • Smart-UPS & 1-Phase Symmetra
  • Release Notes for Smart-UPS & 1-Phase Symmetra Firmware v3.4.0.8
  • Release Notes for Smart-UPS & 1-Phase Symmetra Fir...
  • Release Notes for Smart-UPS v2.5.5.1
  • Release Notes for Smart-UPS v2.5.4 & 1-Phase Symme...
  • Release Notes for Smart-UPS v2.5.3.3 & 1-Phase Sym...
  • Release Notes for Smart-UPS Firmware v3.0.0.12
NMC Support
Request Support
Back to Smart-UPS & 1-Phase Symmetra
Lt. Commander SwathiNaidu Lt. Commander
‎2025-08-26 03:32 AM
Affected Revision Levels
Component  File Details
Smart-UPS Application
Windows:
snst_nmc3_su_3-4-0-8.exe
Linux & macOS:
snst_nmc3_su_3-4-0-8.tar.gz
UPS Application for Smart-UPS, Smart-UPS RT, Smart-UPS VT, MGE Galaxy 3500.
Symmetra Application
Windows:
snst_nmc3_sy_3-4-0-8.exe
Linux & macOS:
snst_nmc3_sy_3-4-0-8.tar.gz
UPS Application for 1-Phase Symmetra, Symmetra LX.
To upgrade to firmware version 3.0 or later, the only supported method is the Secure NMC System (SNS) Tool, which can be downloaded from www.se.com/secure-nmc or by searching for SFNMC3FMTSU. To access the firmware in the software, a valid Secure NMC subscription is required. For more information, see the SNS Tool User Guide.
NOTE: If you upgrade to firmware version 2.0 or later, you cannot downgrade to a firmware version lower than 2.0.
SwathiNaidu_0-1718792359613.pngIf you downgrade from firmware version 2.4+ to a firmware version lower than 2.4, this will cause the card to be formatted, erasing all security certificates, encryption keys, configuration settings, and the event and data logs.
New Features
New Feature
UPS Family
Smart-UPS 1-Phase Symmetra
Support added for viewing the ARP cache in the Command Line Interface (CLI).
Support added for EtherNet/IP for selected UPS devices. For more information, refer to Knowledge Base article FAQ000275863.
NMC now displays the UPS Installation date when supported by the UPS.
Added support for configuring outlet groups from the Command Line Interface.
Security Update
Support added for Multi-Factor Authentication (MFA). MFA adds an additional layer of security to user logins by requiring a one-time password (OTP) sent via email after successful username and password authentication. 
NOTE: Ensure the NMC user credentials used for the SNS Tool, EcoStruxure IT and Data Center Expert communications do not have email addresses configured. For more information, see Knowledge Base article FAQ000276382.
Fixed Issues
Fixed Issue
UPS Family
Smart-UPS
1-Phase Symmetra
Unsuccessful e-mail tests are now displayed as expected in the Web UI.
Styling for the “Password Change Required” web page now displays as expected in the latest update of Chrome. 
You can now cancel an initiated firewall test as expected in the Web UI.
CIDR (Classless Inter-Domain Routing) notation is now allowed in SNMP NMS fields and firewall fields (when in subnet mode). 
The CIDR notation is now functional in the DNS field and NMP access is now allowed or blocked based on the ranges associated with the network. 
DNS lookups previously returned unusable IPv6 addresses in certain scenarios when both IPv4 and IPv6 were enabled (default settings). IPv4 is now prioritized if the NMC has an IPv4 address and only a link-local IPv6 address.
The NMC now shows the correct RBC SKU string for battery replacement.
The NMC now properly supports USB flash drives for accessing configuration options via the UPS display.
Security Update
The following security vulnerability has been addressed in this release:
  • CWE-120: Buffer Copy without Checking Size of Input vulnerability exists that could cause the device to become unresponsive when malformed SNMP requests are received over the network. 
  • CWE-476: NULL Pointer Dereference vulnerability exists that could cause the device to become temporarily inaccessible when receiving malformed IPv4 packets.
  • CWE-613: Insufficient Session Expiration vulnerability exists that could cause a user to maintain access to an existing session when their password has been changed. 
Known Issues
Known Issue
There is no known issue in this release.
Hash Signatures
Windows
Signatures snst_nmc3_su_3-4-0-8.exe
CRC32
45B34E48
CRC64
D073654FF833808B
SHA-256
35B2DE418E22D5241CB36A94C15FEBAF49E6AA46E90FA84BE685CBC4218EC70C
SHA-1
BAF4343761DB6D3DA916ECA5836A1F0131653F81
BLAKE2sp
E53287ED5744059A72F1BC59A911082E09B8548E2F4EA01F9A34FB796F362FEE
Signatures snst_nmc3_sy_3-4-0-8.exe
CRC32
F3BF4CCF
CRC64
907C7F8101C41264
SHA-256
4A84BB6DBE87313FBF9F751118EE0BE3036749713E87A61AFCEED92FCDCDB802
SHA-1
7D2451F2CC1B2E4FA5E34DB3EF342204268FADB4
BLAKE2sp
DBE7CDEF8B615F592E8E5E3EB531DC7ED166C5A78B8B01164C6016838BDE21EA
Linux
Signatures
CRC32
F4C123A8
CRC64
002F814120317B02
SHA-256
66CE945D8D13811760DF1E249C51B492415F62DDBD8A329E4FFF3F8F14AD14C8
SHA-1
242548A1D794AB86D8B31527FFB1C9025A2DF5A9
BLAKE2sp
4E9F592B433E6E467B964231D70E19829B6B19955DED67B185F33AFBE7926A62
Windows
Signatures snst_nmc3_sy_3-4-0-8.tar.gz
CRC32
316540EB
CRC64
AE3E7B930CA360D9
SHA-256
272EF5CE98C18C3AA9E8D822799C77B4194F36808F4FAF5F0075BF15A9092B00
SHA-1
88A7B68E9791FFFC8ABA11F1ADF90AE192B01293
BLAKE2sp
A903D65FE11A55F38F62D50A9C42742B42436407EF9B87A63037D958181F72E6
macOS
Signatures
CRC32
DC9E7DE1
CRC64
D24D77554F730E68
SHA-256
0B5562C2A883AA31EA105F90FB2E7AEBDFADA314418051ABC6F8DBA737F62111
SHA-1
6DCF6023F9A70FFF7710F91B425F5908C1D5D2A3
BLAKE2sp
93731344D22790B9080573089A7F8F41A3071BB5F3A30D09C028068A6A9E8D6B
Signatures
CRC32
64EAFB15
CRC64
2B47491CD052BDCA
SHA-256
0634E006909A90B4EA1A6F2B7656324E63295AD2D3F9247D67C9E23ED548BBA4
SHA-1
DC266F489C01758913375596211CFEE2955206F0
BLAKE2sp
62CB4EAE53E5B6390E5EB56FF857536D7EC91D2AAE169437F0D044B06FC03BE9
