Release Notes for Smart-UPS v2.5.3.3 & 1-Phase Symmetra Firmware v2.5.3.2
Smart-UPS & 1-Phase Symmetra
  • EcoStruxure IT Help Center
  • Network Management Cards
  • Network Management Card 3
  • Smart-UPS & 1-Phase Symmetra
  • Release Notes for Smart-UPS v2.5.3.3 & 1-Phase Symmetra Firmware v2.5.3.2
NMC Support
Request Support
Back to Smart-UPS & 1-Phase Symmetra
Lt. Commander SwathiNaidu Lt. Commander
‎2024-11-15 09:48 AM
Affected Revision Levels
Component  File Details
Smart-UPS Application apc_hw21_su_2-5-3-3.nmc3 UPS Application for Smart-UPS, Smart-UPS RT, Smart-UPS VT, MGE Galaxy 3500.
Symmetra Application apc_hw21_sy_2-5-3-2.nmc3 UPS Application for 1-Phase Symmetra, Symmetra LX.
For details on upgrading the UPS Network Management Card 3 (NMC 3) firmware, see the NMC3 User Guide.
NOTE: If you upgrade to firmware version 2.0 or later, you cannot downgrade to a firmware version lower than 2.0.
SwathiNaidu_0-1718792359613.pngIf you downgrade from firmware version 2.4+ or later to a firmware version lower than 2.4, this will cause the card to be formatted, erasing all security certificates, encryption keys, configuration settings, and the event and data logs.
New Features
New Feature
There is no new feature in this release.
Fixed Issues
Fixed Issue
UPS Family
Smart-UPS
1-Phase Symmetra
Downloading the Event Log via the Web UI works as expected when the language is set to Japanese.
Security Update
The following security vulnerability has been addressed in this release:
 CWE-200: Exposure of Sensitive Information to an Unauthorized Actor
SSH Cipher Block Chaining (CBC) cipher has been removed.
The following security vulnerabilities have been addressed in this release:
  • CWE-523: Unprotected Transport of Credentials. Login pages do not use adequate measures to protect the user name and password while they are in transit from the client to the server.
  • CWE-319: Cleartext Transmission of Sensitive Information. The product transmits sensitive or security-critical data in cleartext in a communication channel that can be sniffed by unauthorized actors.
The user is now referenced as an index rather than their username, for example: NMC/KrtUvuh39YtQmHbyua297g/usercfg.htm?user=2
  CWE-863: Incorrect Authorization
The Network-Only user can only perform actions in the Web UI relevant to the user access level.
CWE-20: Improper Input Validation
Incoming BACnet packet sizes are now validated.
CWE-598: Use of GET Request Method With Sensitive Query Strings. This software uses the HTTP GET method to process a request and includes sensitive information in the query string of that request.
Configuration of HSTS is now independent from HTTP or HTTPS configuration. When HSTS is enabled an STS header is added to all responses over HTTPS.
Known Issues
Known Issue
There is no known issue in this release.
Hash Signatures
Signatures apc_hw21_su_2-5-3-3.exe
CRC32 1B525C68
CRC64 1919EC007B13BC96
SHA-256 C641E5D549CB88F6CDF914A9BD79A3F450118FC9CE6ADA47EA35A5C96FFA77C1
SHA-1 BCF0BE585DD3E21AF7A3ADA8F7893B5A0B8F1198
BLAKE2sp 6DBF86236F9B6EE639B42A883F832182ADF9990D99801ECD5FA4B8D1E42F56FA
Signatures apc_hw21_sy_2-5-3-2.exe
CRC32 04E90885
CRC64 20EA59213CDCA39E
SHA-256 091163C905F29652AB41B4ABE12CA45402376B6CACD80E5911C9DDB2CC308134
SHA-1 FCFB7578356DFC98253BDDCBA2C483AF76DF8A43
BLAKE2sp 50CC9F255DE9DF12FB94C3AAD92661500CBB05FEB4A5DEF8BCDF1691529D4736
