Release Notes for Smart-UPS & 1-Phase Symmetra Firmware v3.2
Send InviteCancel
UPS Application for 1-Phase Symmetra, Symmetra LX.
To upgrade to firmware version 3.0 or later, the only supported method is the Secure NMC System (SNS) Tool, which can be downloaded fromwww.apc.com/secure-nmcor by searching for SFNMC3FMTSU. To access the firmware in the software, a valid Secure NMC subscription is required. For more information, see theSNS Tool User Guide.
NOTE:If you upgrade to firmware version 2.0 or later, you cannot downgrade to a firmware version lower than 2.0.
If you downgrade from firmware version 2.4+ to a firmware version lower than 2.4, this will cause the card to be formatted, erasing all security certificates, encryption keys, configuration settings, and the event and data logs.
New Features
New Feature
UPS Family
Smart-UPS
1-Phase Symmetra
The NMC3 platform and Smart-UPS and 1-Phase Symmetra applications are now IEC 62443-4-2 SL2 certified; a higher level of certification than SL1 announced in October 2023.
Support added for optional Spot Fluid Sensor (NBES0301).
Support added for configuring Universal I/O sensors via the cfguio command on the Command Line Interface (CLI).
Support added for audit logging to ensure that control actions and configuration changes are recorded in the Event Log.
Security Update
Support added for integrity checking of the configuration file.
Fixed Issues
Fixed Issue
UPS Family
Smart-UPS
1-Phase Symmetra
SSH and Telnet sessions now terminate as expected.
The Web UI now supports the Primary and Secondary DNS fields with a maximum of 40 characters.
An error no longer appears when trying to access certain Web UI pages as a Network-Only user.
NMC no longer reboots when configuring 'Controlled Early Shutdown' parameters from the configuration file.
It is now possible to navigate from the Universal I/O status web page to other web pages.
Security Update
The following security vulnerability has been addressed in this release:
CWE-863: Incorrect Authorization
The Network-Only user can only perform actions within the Web UI that corresponds to their access level.
