Release Notes for Smart-UPS Firmware v3.0.0.12
Smart-UPS & 1-Phase Symmetra
  • EcoStruxure IT Help Center
  • Network Management Cards
  • Network Management Card 3
  • Smart-UPS & 1-Phase Symmetra
  • Release Notes for Smart-UPS Firmware v3.0.0.12
  • Release Notes for Smart-UPS & 1-Phase Symmetra Fir...
  • Release Notes for Smart-UPS v2.5.5.1
  • Release Notes for Smart-UPS v2.5.4 & 1-Phase Symme...
  • Release Notes for Smart-UPS v2.5.3.3 & 1-Phase Sym...
NMC Support
Request Support
Back to Smart-UPS & 1-Phase Symmetra
Lt. Commander SwathiNaidu Lt. Commander
‎2024-06-19 03:55 AM
Last Updated: Commander CDiggin Commander ‎2024-06-25 06:40 AM
Affected Revision Levels
Component  File Details
Smart-UPS Application apc_hw21_su_3-0-0-12.nmc3 UPS Application for Smart-UPS, Smart-UPS RT, Smart-UPS VT, and MGE Galaxy 3500.
To upgrade to firmware version 3.0 or later, the only supported method is the Secure NMC System (SNS) Tool, which can be downloaded from www.apc.com/secure-nmc or by searching for SFNMC3FMTSU. To access the firmware in the software, a valid Secure NMC subscription is required. For more information, see the SNS Tool User Guide.
NOTE: If you upgrade to firmware version 2.0 or later, you cannot downgrade to a firmware version lower than 2.0.
SwathiNaidu_0-1718792359613.pngIf you downgrade from firmware version 2.4+ to a firmware version lower than 2.4, this will cause the card to be formatted, erasing all security certificates, encryption keys, configuration settings, and the event and data logs.
Schneider Electric Device IP Configuration Wizard
The Device IP Configuration Wizard is a Windows application designed specifically to remotely configure the basic TCP/IP settings of Network Management Cards. The Wizard runs on Windows® Server 2012, Windows Server 2016, Windows Server 2019, Windows 8.1, and Windows 10. This utility is for IPv4 only.
NOTES:
  • In firmware version v1.4.x and higher, it is not supported to assign IP addresses to Network Management Cards using the Wizard.
  • You cannot search for assigned devices already on the network using an IP range unless you enableSNMPv1 and set the Community Name to “public”. For more information on SNMPv1, see the User Guide.
  • When the NMC IP address settings are configured, to access the NMC Web UI in a browser, you must update the URL from http to https.
New Features
New Feature
The NMC3 platform and Smart-UPS application are now IEC 62443-4-2 certified.
Support has been added for audit logging to ensure control actions and configuration changes are recorded in the Event log.
Support has been added for remote authentication via the TACACS+ protocol.
Security Update
Password security has been updated to align with the requirements for IEC 62443-4-2.The NMC now supports UPS firmware updates while the UPS is in Manual Bypass mode.
Fixed Issues
Fixed Issue
SNMP OID upshighprecbatterypackonly now correctly displays all information about Battery Packs.
The NMC3 Web UI now allows passwords with up to 64 characters, as expected.
For encrypted email settings, install CA certificate in the certificate store and set "Require CA Root Certificate" correctly.
Improved TLS certificate for email.
Security Update
The following security vulnerabilities has been addressed in this release:
  • CWE-74: Improper neutralization of special elements in output used by a downstream component (injection)
  • CWE-79: Improper neutralization of input during web page generation (Cross-site Scripting).
Known Issues
Known Issue
The audit log of the Web UI is currently only available in English.
Hash Signatures
Signatures snst_nmc3_su_3-0-0-12.exe
CRC32
CED0ED3C
CRC64
0561C9C18A9E643C
SHA-256
EB5245DFC880F7A8F4FA17484347FA9E0E4BE7EF1FD7E7C6FDA441A268E084D2
SHA-1
A7A7197534FD0FD4F6D8950ACFB6537F59D69FCC
BLAKE2sp
B33E36481699B0A7B5A029E78EC47914C5D0192614B79C794EE399689C7CE4D9
