Modicon PAC Forum
  • Industrial Automation
  • Modicon PAC Forum
  • Mark all as New
  • Mark all as Read
  • Float this item to the top
  • Invite a Friend
  • Threaded format
  • Linear Format
  • Sort by Topic Start Date
The message you are trying to access is permanently deleted.
Top Labels
Top Labels
  • Alphabetical
  • 02. Modicon M580 ePAC 149
  • 06. EcoStruxure Control Expert 115
  • 05. Networking & Communication 75
  • 01. Modicon M340 PAC 61
  • 04. Modicon X80 IO 33
  • 00. Read me first 24
  • 07. Modicon PAC Legacy 23
  • 12. Other 23
  • 03. Modicon PAC Safety 22
  • Smart Design & Engineering 19
  • 08. Tools & Resources 17
  • Edge Control 10
  • Connected Products 7
  • App Analytics & Services 4
  • 13. To be deleted 4
  • Smart Operations 3
  • 09. Surveys 3
  • 10. Australia 3
  • Tips and ideas 3
  • Energy Efficiency 3
  • PLC 2
  • 11. USA 2
  • IT Expert 2
  • Asset Performance 2
  • Modbus communication. RS485 1
  • Cybersecurity 1
  • Energy meter 1
  • PowerTag Energy 1
  • usb 1
  • EcoStruxure Automation Expert 1
  • Product Feedback 1
  • Hybrid segment 1
  • Training 1
  • Cyber Security 1
  • M340 1
  • power monitoring expert 1
  • Drivers 1
  • Workforce Empowerment 1
  • Previous
  • 1 of 4
  • Next
Trinxs1
Commander Trinxs1 Commander
11
YONGHO-KIM
Lieutenant YONGHO-KIM Lieutenant
9
ciupol
Lt. Commander ciupol
9
Thumbnail of Modicon M580
Modicon M580
56
Thumbnail of EcoStruxure™ Control Expert
32
Thumbnail of Modicon M340
Modicon M340
29
Load more
Modicon PAC Forum
  • All
  • Solved
  • Unsolved
  • Unanswered
ciupol
Structured Text Continue instruction
Welcome, There doesn't seem to be CONTINUE instruction available in Structured Text in Control Expert. How would you continue to next loop iteration without this instruction? Thanks, ciupol
Industrial Automation icon_circle Modicon PAC Forum
36 0 0
2025-12-10
Djamel12
Djamel12
M580 NOC301 lire les registres Inputs 3000 avec DTM
Bonjour, j'ai un M580 avec NOC301 et j'aimerai lire des registres Inputs 3000 est ce possible en utilisant les DTM pas de block ADDM Merci
70 0 0
2025-12-09
suharman_saputr
Crewman suharman_saputr
Print Documentation Control Expert
Hi, is there any way to print documentation on Control Expert in full screen fit on one page? rather than limit print area on grid. because the break section sometimes cut the function block display. ...
116 0 1
Latest Reply: MOHAMMADSAMEERKHAN
Informational
MrBong
Ensign MrBong
How to configure Modbus tcp/ip data in M580
How to read data from modbus tcp/ip in M580. I tried ADDM & ADDMX and Read_var but not getting data. Please guide further.
17314 0 30
Latest Reply: wpschuster
Eyanto
Ensign Eyanto
BMX SDO 0802 Compatibility with Shunt Trip Coil
Hi all, I need some clarification on the compatibility of the BMX SDO 0802 with a shunt-trip coil. According to the I/O module specification, each channel is capable of driving up to 0.5A. Channel 1 ...
73 0 0
2025-12-04
bogado11
Crewman bogado11
How to configure Modbus TCP in machine expert Basic with TM200CE32R
Hello, I have a modicon TM200CE32R and I am trying to test modbus tcp with other devices. I am trying to use the modicon as a slave and another device as a master however when I follow the instructions...
105 0 0
2025-12-01
JimL
JimL
SFC Action Cross Reference
With an SFC, the action code is in a subfolder under the chart. Is it possible to cross reference any of the action code and find out where in the SFC it is actually called to run or find out if it is ...
51 0 0
2025-11-27
benjaminguilleux
benjaminguilleux
Control expert DIF V15.2 HF1 - Comparaison de données
Bonjour, Je fais partie d'une société ou nous sommes intégrateur de solutions chez nos clients. Nous utilisons le logiciel control expert classic en v15.1 (migration en v16.2 prévu bientot) ainsi que c...
134 0 0
2025-11-27
BennyJoseph
Crewman BennyJoseph
M340 Modbus RS485 – READ_VAR Works but WRITE_VAR Fails (Slave Timeout)
Hi all, Could someone please help me with the issue below? I am facing a problem when trying to send a WRITE command from an M340 controller to a Modbus slave device over Modbus RS485 serial communicat...
625 0 7
Latest Reply: BennyJoseph
RuchirSomani
Crewman RuchirSomani
How to detect Modbus Communication Failure at Modicon M580?
Hi, I need to understand how to find/configured in Control Expert for M580 whether Modbus Communication with any Modbus Slave device is working or has stopped ?Is there any fail/error bit/code to sen...
7974 0 14
Latest Reply: PeiHsin
mliew
mliew
Simulating process task failure
Is there any way to simulate a process task failure on M580 safety PLC? My code currently has data that is being transferred between process and safety task. The purpose of the simulation is to demons...
242 0 2
Latest Reply: mliew
  • « Previous
    • 1
    • 2
    • 3
    • 44
  • Next »
