Continue
  • My Subscriptions
  • Events
PM8000 Current High Measurement
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM8000 Current High Measurement
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
swil
swil
Mentor
Posted: ‎2020-06-28 06:13 PM
2543
Hi. If a board trips, at say 11:50:03, and the PM8000 loses power and is not able to log the Voltage High at the next interval (11:51am), when power is restored at 2pm, will the peak current that occurred at 11:50:03 be logged to the PME with a timestamp of 2pm?  See attached screenshot.
  • PM8000
Charles_Murison
Champion
Posted: ‎2020-06-30 05:06 PM
2535
Hello @swil ,
If you look at the ION reference document Maximum module section, under "Responses to special conditions":
When the module is started or powered-up (either the first time, or after a shut-down) -> The Maximum output register retains the value it held at shutdown.
This is to say that when the meter was powered back on, the maximum module retained the maxmimum value it had at shutdown. What I cannot say is if there was a new maximum between the time the meter powered on and the next interval recorded.
Charles
Replies 4
Tom_Stevenson
Tom_Stevenson Champion
Champion
Posted: ‎2020-06-30 04:17 PM
Hi swil - I am assuming you are referring to an onboard log.  In this case, the record will be missing in PME.  PME has a data quality tool that let's you insert missing records.
Tom
Charles_Murison
Champion
2535
Hello @swil ,
Charles
swil
swil
Mentor
Posted: ‎2020-06-30 05:12 PM
Thank you, Charles.
Tom_Stevenson
Champion
Posted: ‎2020-06-30 05:29 PM
Thanks Charles !
