Continue
  • My Subscriptions
  • Events
PM5330 into JACE8000 over RTU
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM5330 into JACE8000 over RTU
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
DickyGray
DickyGray
Explorer
Posted: ‎2024-11-03 11:54 AM
1326
Spoiler
Pm 5330 modbus rtu registers
Hi all,
I have some points that are being difficult to read. L3 to neutral just comes back as a null. L1 & L2 - N are fine. All of the Float Holding registers have required + 1 to read in Niagara. The L3-N hasn't liked with or without the +1. Also,  is the comms heartbeat available as a register ?
Any ideas ?
Richard
  • PM5000
Jesus_Diaz
Jesus_Diaz Leader
Leader
Posted: ‎2024-12-13 04:52 PM
Hi @DickyGray ,
If the data log was enabled in the PM5330, you may be able to extract the data from the meter using ION Setup.
You need to navigate to the data screen view (View > Data Screens) and enter Data Log #1. Here, you should be able to see the Active Energy Delivered and Received. Depending on the data log configuration, you may have different parameters in the log, but only two parameters can be enabled. Then, select the data you want to export (Ctrl + A to select all) and export it as a CSV file.
Best Regards,
JD
Jesus_Diaz
Jesus_Diaz Leader
Leader
Posted: ‎2024-11-04 01:25 PM
1
1308
Hi @DickyGray,
What is the power system configuration of the meter? Some power systems may not have L3-N values.
Could you also check the meter's front panel to see if the L3-N value is shown?
Additionally, please try using the Modbus Tester to read the registers.
Best regards,
JD
DickyGray
DickyGray
Explorer
Posted: ‎2024-12-11 02:19 AM
Thanks JD,
We managed to get that working fine.
We have another issue. Because the contractors didnt use the ION set tool for these, nothing has been done on the logs. What we want to do, but I am not sure if this can work, is :
Have a loss of comms alarm disable the logging at the Jace, on restoration of comms, retrieve the data not captured during comms loss.
i assume I need to get the logs sorted out on the meter via ION before this work. ?
Jesus_Diaz
Jesus_Diaz Leader
Leader
Hi @DickyGray ,
Best Regards,
JD
