Continue
  • My Subscriptions
  • Events
MODBUS Import Module is missing in PM8000 ION Framework
Metering & Power Quality
  • EcoStruxure Power & Grid
  • MODBUS Import Module is missing in PM8000 ION Framework
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Bojan
Bojan Leader
Leader
Posted: ‎2017-05-01 04:49 PM
2080
I planned to use MODBUS Import Module to read Relay Word bits in SEL-751 Feeder Protection Relay from PM8000, but then I realized that the module is missing from the ION Framework.
What would be a replacement / work-around for it?
For example, how can I read the following MODBUS Slave SEL-751 logical 1 and 0 statuses from MODBUS Master PM8000 meter:
Bojan
Bojan Leader
Leader
Posted: ‎2017-05-02 11:08 AM
Patrick Lynch from Tech Support explained to me how to designate two bytes via the modbus master device module in ION Framework:
Replies 4
Yut
Yut
Leader
Posted: ‎2017-05-01 10:58 PM
2
2016
Use Modbus Device Master module and Modbus Master Map module.
Bojan
Bojan Leader
Leader
Posted: ‎2017-05-02 07:55 AM
2016
Hi Yut,
I use Modbus Device Master module and Modbus Master Map module to read INT16 values, but how can I read the bit status from it?
In C# I would do the following, but have no idea how to program it in ION Framework:
Bojan
Bojan Leader
Leader
Yut
Yut
Leader
Posted: ‎2017-05-07 09:15 PM
I have an idea of Arithmetic Module compare the value to the mask value in decimal using IF function.
