Continue
  • My Subscriptions
  • Events
Interoperability Test for ION8650 meter on DC Auxiliary Power Supply
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Interoperability Test for ION8650 meter on DC Auxiliary Power Supply
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
Parlindungan_Sitorus
Parlindungan_Sitorus Contributor
Contributor
Posted: ‎2022-03-23 02:19 AM
2547
Dear All Expert,
We will face a testing on Interoperability Test for ION8650 meter which will be carried out by the research and development center of PLN (government company) in Indonesia.
One of the tests is on the DC Auxiliary Power where later it will be tested by doing the opposite polarity whether the ION8650 will work or not or the ION meter power supply component will be damaged.
The target of this test is, even though the user when wiring the DC Auxiliary Power is reversed the polarity, but the power supply component of the ION8650 is expected to have no problems.
If the ION8650 Power Supply damage, then the Interoperability Test result will failed.
Any experience on this?
Need advice so we can prepare the necessary for this testing.
Best regards,
Parlindungan Sitorus.
  • ION8000
DanL
DanL Champion
Champion
Posted: ‎2022-03-23 10:01 AM
2514
Both available ION8650 Auxiliary Power Supply order options (H and J) are rated for either AC or DC operation. Their design includes a full wave bridge rectifier and is fully tolerant to polarity reversal.
Please ensure the applied DC voltage falls within the rated DC operation range for the meter order option being tested.
Dan
Charles_Murison
Champion
Posted: ‎2022-03-23 09:40 AM
Hello @DanL
Are you able to response to this question?
Charles
DanL
DanL Champion
Champion
2514
Dan
Contributor
Posted: ‎2022-03-23 06:52 PM
Dear Dan,
Thank you for your response.
Best regards,
Parlindungan
