Continue
  • My Subscriptions
  • Events
Password loss PM710
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Password loss PM710
Charles_Murison
Charles_Murison Champion
581
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
SESA528
SESA528 Contributor
Contributor
Posted: ‎2022-03-16 09:19 AM
4980
Password loss PM710
Hi team,
My customer lost password of PM710 (OS 3.150). Pls help me recover password my customer. (Customer agreed)
Attached information Power Meter. Thanks very much.
  • PM Guidebooks
mostafa
mostafa Mentor
Mentor
Posted: ‎2022-03-16 11:27 AM . Last Modified: ‎2022-03-16 01:24 PM
4972
Hi Nghi,
For PM700 meters with OS version 3.040 or higher like yours, there is a tool that Technical support has access to.
You need to contact them for the recovery password.
Bests,
Mostafa
Charles_Murison
Champion
Posted: ‎2022-03-21 11:51 AM
4840
Hello @SESA528 ,
Tech Support cannot give you the tool. They can however use the tool and give you the password. I have sent a note to the person who has bfo case #89442579.
Charles
Replies 10
mostafa
mostafa Mentor
Mentor
4972
Hi Nghi,
Bests,
Mostafa
SESA528
SESA528 Contributor
Contributor
Posted: ‎2022-03-17 08:44 AM
4939
Hi @mostafa ,
Follow your answer: "there is a tool that Technical support has access to. You need to contact them for the recovery password"
=> Pls give for me contact Technical support or give for me this Tool recovery password.
Thanks very much.
Charles_Murison
Champion
Posted: ‎2022-03-17 08:51 AM
4937
Hello @SESA528
you can go to se.com -> support -> contact support.  If your country is selected you can see options to contact technical support.
Charles
SESA528
SESA528 Contributor
Contributor
Posted: ‎2022-03-17 09:27 AM
4930
Hi @Charles_Murison ,
I asked Technical support my country and receive answer below:
"Dear Nghi
Pls noted that. The latest version firmware  PM710 is 3.150 > 3.040 as mentioned below
"Backdoor password will work on PM700 meter only if the firmware/OS version is 3.040 or above."
The following link is to the latest firmware for a PM710 Series meter:
PM710 firmware (V3.150)
Pls follow up guideline FAQ and do reload firmware 3.150"
=> I don't know what do they say. During my OS PM710 is 3.150 but they recommend for me upgrade? I don't any tool for recover password.
Charles_Murison
Champion
Posted: ‎2022-03-17 11:41 AM
5
4925
Hello @SESA528,
I would push back against Tech support and if needed ask them to escalate to the next level. The firmware version of the meter is indeed above minimum required.
Charles
SESA528
SESA528 Contributor
Contributor
Posted: ‎2022-03-20 10:22 AM
4871
Yes. Pls help me push Technical support and give for me this tool backdoor because they don't send for me any tool.
Yarom
Yarom Troubleshooter
Troubleshooter
Posted: ‎2022-03-20 11:45 AM
4868
HI There Lt. Commander Bui,
The proper procedure for any password resettable power meters is to escalate through bFO to Level 2 advanced technical support.  There is either someone there that has the tool, and authorized to use it or they themselves escalate to their support.
If you are still having trouble, you can send me the serial number and model of the power meter (image of the label would be good as well) and I can get our L2 support to obtain the master password.
I would need the contact information (yours or client account) so that I can set up a case in bFO to escalate.
Best regards,
Yarom
Charles_Murison
Champion
4840
Hello @SESA528 ,
Charles
SESA528
SESA528 Contributor
Contributor
Posted: ‎2022-03-24 08:37 AM
Thanks very much. I'm clearly
SESA528
SESA528 Contributor
Contributor
Posted: ‎2022-03-24 08:38 AM
HI @Yarom ,
Thanks very much
