ION9000 Transient Module: cannot find Detection Mode option in setup registers
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • ION9000 Transient Module: cannot find Detection Mode option in setup registers
Charles_Murison
Charles_Murison Champion
566
Mehran_Mehrnia
Mehran_Mehrnia Champion
194
Ramasamy_N
Ramasamy_N Champion
115
Stuart_Cheng
Stuart_Cheng Contributor
Contributor
Posted: ‎2024-03-26 06:32 PM . Last Modified: ‎2024-03-26 06:32 PM
1837
Hi All,
We were testing ION9000 Transient Module and found that no “Detection Mode” option in the setup register. We have tried v003.001.000 and v004.000.000, but neither of them has. Does anyone know the reason? Thanks
  • ION9000
Mehran_Mehrnia
Champion
Posted: ‎2024-03-27 07:16 AM
Hi @Stuart_Cheng
‘Detection Mode’ is not present on all meters except ION8650 meters at this time and by default the ‘Waveshape’ method of Detection Mode is used with ION9000/PM8000/ION7400 meters.
Also there is one NOTE statement under each modules in ION Reference indicating:
Best Regards,
-Mehran
L3 Expert Technical Support Specialist
Replies 5
Mehran_Mehrnia
Champion
Hi @Stuart_Cheng
Best Regards,
-Mehran
Stuart_Cheng
Contributor
Posted: ‎2024-03-27 08:03 AM
1796
Hi @Mehran_Mehrnia,
Many thanks for your reply. May I know the reason why the detection mode is only designed for ION8650? Thanks
Charles_Murison
Champion
Posted: ‎2024-03-27 08:29 AM
1792
@Stuart_Cheng Will respond in a private message.
Charles
YonKhoerul
YonKhoerul Contributor
Contributor
Posted: ‎2024-04-01 07:31 PM
1718
May I know the same regarding this?
The factory team and I are working on a project with the same device.
Yon Khoerul
Charles_Murison
Champion
Posted: ‎2024-04-02 08:52 AM
Hello @YonKhoerul ,
Short answer is ION8650 and ION9000 have different code and are not part of the same platform. If you need this feature, contact your sales team to work with them to create a feature request.
Charles
