ION 7300 CONFIGUATION USING SERIAL + ION 7403 CONFIGUATION USING SERIAL OR Ethernet
Metering & Power Quality
  • EcoStruxure Power & Grid
  • ION 7300 CONFIGUATION USING SERIAL + ION 7403 CONFIGUATION USING SERIAL OR Ethernet
Charles_Murison
Picard Charles_Murison Picard
525
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
138
Ramasamy_N
Captain Ramasamy_N Captain
115
PowerLogic
PowerLogic ION7400 series
Posted: ‎2022-08-27 12:28 PM . Last Modified: ‎2022-08-28 05:26 AM
2122
Dear  Sir ,
what is the best way to communicate using RS-485 communication with ION 7300 , and please recommend for me the best  test equipment to use it for communicate with ION 7330 device
is MOXA USB TO SERIAL (RS-485) is sufficient?
Please note that there is no ethernet interface.
as well what is the best way to communicate with ION 7403, is it Ethernet or Serial and in case of serial please recommend for me the best  test equipment to use it for communicate with ION 7403 device
please note that  i dont have display for both models , is there any solutions?
Regards ,
  • Thumbnail of PowerLogic ION7400 series
    PowerLogic
View products (1)
  • ION7000
Tags (3)
  • ion 7300
  • ion7400
Charles_Murison
Posted: ‎2022-08-29 09:06 AM
Hello @Anonymous user
ION7300 series, these meters are obsolete. There is limited support. Without Ethernet connection serial is your only option. Without a display may be hard to determine the protocol of the serial ports. Could be ION, could be modbus or others. If ION, you could possibly use the software ION Setup (https://www.se.com/ca/en/download/document/ION_Setup_Latest_Release/)
ION7400 series, recommend using Ethernet. If you connect to the meter directly to a computer and run Wireshark or other packet capture software, you will see the meter send and ARP message that includes it's IP address. From this you can use ION Setup to configure the device.
Charles
Charles_Murison
Charles
