Harmonic Display Mode
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • Harmonic Display Mode
Charles_Murison
Charles_Murison Champion
571
Mehran_Mehrnia
Mehran_Mehrnia Champion
202
Ramasamy_N
Ramasamy_N Champion
115
Posted: ‎2017-10-03 12:37 AM . Last Modified: ‎2020-04-22 01:14 AM
948
HI all,
I have a problem. When i set Harmonic Display Mode by ION setup in ION7650 (image below).
But,  I see display Harmonic just V1 and I1.
I want display V2, V3 Harmonic Display Mode and I2, I3 Harmonic Display Mode. How do i do that. Thanks very much.
  • ION Setup
Yut
Yut
Leader
Posted: ‎2018-01-02 08:44 PM
I suggest to use advance mode to edit the module for 3 phases harmonics.
Robert_Lee
Robert_Lee Champion
Champion
Posted: ‎2018-01-03 01:49 PM
Are you using the Localization wizard to adjust the settings (and not just attempting to edit the single register)?  The main display is just showing single registers at the moment (similar to how waveform depths are all adjusted together but on the primary setup value is being shown only on a single register).
The setup wizard also depend on being able to identify the template in use properly so if you are using a non-factory template string, it will not be able to properly program the multiple modules.
