Anyone successfully configure PM5320 MODBUS TCPIP?
Metering & Power Quality
Showing results forย
Did you mean:ย
Select a Country
  • EcoStruxure Power & Grid
  • Anyone successfully configure PM5320 MODBUS TCPIP?
Charles_Murison
Charles_Murison Champion
566
Mehran_Mehrnia
Mehran_Mehrnia Champion
195
Ramasamy_N
Ramasamy_N Champion
115
Posted: โ€Ž2014-06-24 08:58 PM
4509
Hi
We have problem reading PM5320 with MODSCAN. Is IONSetup the only tool to configure PM5320?
-Abon
LaurentCoene
LaurentCoene Leader
Leader
Posted: โ€Ž2014-07-01 06:33 PM
2
4354
YES! Finally received my unit! (Thanks )
It's very easy but, there's a trick!
I connected mine to my Com'X200. Here are the steps:
First the meter:
-- Go to Maint in the menu (Maintenance)
-- Select Setup and click OK (if you have changed the default password which is 0000)
-- Click on Comm
4063
From there you can change the IP settings of your device. Note that a static IP is called "Stored" IP on the device. Once you defined the IP, you are ready to talk to the meter. Note that there's nothing around Modbus (since modbus is not supported by this meter), so stop looking!!!
Then login on your Com'X200, go to the "Device Settings" tab, make sure the Com'X is selected in the tree, and go to the Ethernet section.
In the "No Device Connected" drop-down, select "Create a new device".
4073
In the new screen, you will have a Device Type drop down. Select the PM5320. Note that you must have at least firmware version 1.1.14. It's not there in 1.0.14!!
Then in the Configuration section, enter the IP of your meter and (drum roll) you need to enter the Slave ID. The slave ID is 255. (Thanks to for that valuable information!).
4074
Click on Create! And you're done!!! ๐Ÿ™‚
Works perfectly! ๐Ÿ™‚
Replies 5
LaurentCoene
LaurentCoene Leader
Leader
Posted: โ€Ž2014-06-24 10:35 PM
I've also had some issues with it while in Taiwan actually!
Was trying to connect it to the Com'X.
I've ordered one meter to do further testing but haven't received it yet.
Will keep you updated on my findings.
Anyone else?
LaurentCoene
LaurentCoene Leader
Leader
2
4355
First the meter:
-- Click on Comm
4063
4073
4074
Posted: โ€Ž2014-07-01 06:44 PM
4354
Hi Laurent,
Some of our customers do not have ComX200. Anyway they can configure PM5320 w/o ComX 200?
Robert_Lee
Robert_Lee Champion
Champion
Posted: โ€Ž2014-07-03 09:48 AM
You should be able to use ION Setup to connect to the device directly via Ethernet by adding it to a direct Ethernet site.
40864087
I'm still waiting on my shipment of the PM5340 so I can confirm that ION Setup will indeed configure these new devices but I've been configuring the PM5330 with no issues (that's serial however).
robski
robski
Explorer
Posted: โ€Ž2017-09-11 08:55 AM
Can slave ID255 of PM5320 be changed for something below 247 (1 ideally).
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2026 Schneider Electric
