Network Summary report
Managing network configurations
Send InviteCancel
You can generate a Network Summary report with an overview of network connections per rack in the selected rooms. The report lists layer 2/3 network gear (such as switches) and layer 1 network gear (patch panels) as well as a summary per rack of mapped and unmapped routes equipment that is connected to a network (such as a server or PDU).
The Tag filter options are available if you have IT Advisor: Capacity.
The generated report displays in the Report View. You can now use the Report View toolbar to navigate the report pages on the screen (arrow icons), or to print or export the report to a file in any of the available formats (Export icon, down arrow for selection of format).
