Configuring network cable types
Managing network configurations
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Configuring the ITA desktop client
  • Managing network configurations
  • Configuring network cable types
  • Mark as Read
  • IT Advisor supported network connector types
  • Route notation in network management
  • Network properties
  • Network configuration example
  • Network Summary report
  • Creating cable trays
  • Configuring network ports
  • Configuring network connections in table view
  • Configuring network connections in rack view
  • Configuring network cable genome properties
  • Configuring layers
EcoStruxure IT Support
Request Support
Back to Managing network configurations
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-06 07:12 AM
You can define color and usage (description) for your cables to easier trace and visualize the routes of your network connections.
You must have user rights to configure network cables. You configure users and user group rights in the web client on the Administration tab.
  1. Go to Tools > Configure Network Cable Types.
  2. Click Add and define a color and a description for your cable.
    These do not depend on the physical cable type in hand but if you want your graphical overview to resemble what you see in your data center, define your cables to resemble their physical appearance.
Note: You must configure each existing cable individually as there is no link between the cable and the Configure Network Cable Types dialog box once the cable has been defined, saved and added to the room layout. So if you define color and usage for a fiber cable, this configuration will not affect the color and description of any fiber cables already in the room layout.
ITA_configure_network_cable_types_360037994634.jpgITA_configure_network_cable_types_360037994634.jpg
Tip: You can edit cable properties and assign the cable type in the Genomes Library. When you create connections later, all the settings from the cable genome will be in place.
See Configuring network cable genome properties
