Configuring network cable genome properties
Managing network configurations
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Configuring the ITA desktop client
  • Managing network configurations
  • Configuring network cable genome properties
  • Mark as Read
  • IT Advisor supported network connector types
  • Route notation in network management
  • Network properties
  • Network configuration example
  • Network Summary report
  • Creating cable trays
  • Configuring network ports
  • Configuring network connections in table view
  • Configuring network connections in rack view
  • Configuring network cable types
  • Configuring layers
EcoStruxure IT Support
Request Support
Back to Managing network configurations
  • Mark as Read
Picard EcoStruxureIT
‎2021-06-10 07:17 AM
You can define your network cable genome including start and end connectors, fan out cable connector count, length, speed, and cable type.
You must have user rights to configure network cables. You configure users and user group rights in the web client on the Administration tab.
  1. Open Genomes select the cable where you want to view or edit properties, and click Physical.
    ITA_919_edit_genome_properties_fanout_cables_4402433880593.pngITA_919_edit_genome_properties_fanout_cables_4402433880593.png
  2. Click Start or End to select connector type.
    Note: There is no additional validation between port type and cable connector type.
  3. If you selected a fan out cable, check the Fan out cable option to define the number of connectors.
    ITA_919_edit_genome_properties_fanout_cables_2_4402433880593.pngITA_919_edit_genome_properties_fanout_cables_2_4402433880593.png
  4. Set the speed, length, and cable type. See Configuring network cable types
