Network properties
Managing network configurations
Send InviteCancel
This section of the Properties dialog box, accessed by right-clicking a piece of network equipment, identifies network attributes associated with it. The information may vary based on the type of equipment.
Network ports
Type
Provides information about the type of network port. The available options include pairs of a regular port and an uplink port.
The regular port is selected for the piece of equipment that makes network available to other pieces of equipment, such as a switch.
The uplink port is selected for the piece of equipment that requires network access.
Description
Provides user-defined information.
Start
Identifies the first port in the port range.
Count
Identifies the amount of ports in the port range.
Speed
Provides information about the network speed.
Connections (available if the dialog box is accessed by right-clicking a component in the rack layout that has routes defined)
Port
Identifies the port number.
Type
Identifies the port type.
Connected to
Identifies the network route between the start and end items.
