Configuring layers
Managing network configurations
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Configuring the ITA desktop client
  • Managing network configurations
  • Configuring layers
  • Mark as Read
  • IT Advisor supported network connector types
  • Route notation in network management
  • Network properties
  • Network configuration example
  • Network Summary report
  • Creating cable trays
  • Configuring network ports
  • Configuring network connections in table view
  • Configuring network connections in rack view
  • Configuring network cable types
  • Configuring network cable genome properties
EcoStruxure IT Support
Request Support
Back to Managing network configurations
  • Mark as Read
Configuring layers
Picard EcoStruxureIT
‎2021-10-20 12:07 AM
A layer is an abstract concept that allows you to model equipment located under the floor, under the ceiling, or over racks in your data center.
Before you model a cable tray, you must first create a layer in the Cable Tray Layers option in the room properties.
To set the height, you select a reference point, Floor to model equipment located under the floor, or Ceiling to model equipment located under the ceiling.
You can also configure layers for locations. All the rooms inside a location inherit the layers defined for that location.
You can create an unlimited number of layers.
See Creating cable trays
