Vista OPC Server Installation and Known Issues
  • Vista OPC Server Installation and Known Issues
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • SESA116857
    SESA116857
‎2018-09-07 04:10 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 11:54 PM
Key information necessary to operate and install Vista OPC Server
TAC Vista
  • Vista Server 5.1.x
  • Vista OPC Server 1.6.1
Following these guidelines and work arounds the proper installation and configuration of TAC Vista OPC Server can be achieved.
Please reference the articles below depending on the situation.
  1. After installing TAC Vista OPC server it does not show up as a Windows service: Proper license is required before installation
  2. OPC server for TAC Vista will not keep the login settings in the TAC Vista OPC Server setup: Login Settings require additional steps
  3. Installing and configuring Vista OPC Server: Step by Step installation and configuration steps
  4. Unable to access data on a Vista OPC Server that reside on Xenta Server (I/NET or 3rd Party protocol...: Server address limitations
  • 4333
