OPC server for TAC Vista will not keep the login settings in the TAC Vista OPC Server setup
  • OPC server for TAC Vista will not keep the login settings in the TAC Vista OPC Server setup
  • Cody_Failinger
    Cody_Failinger
  • sesa150555
    sesa150555
‎2018-09-07 03:27 AM
OPC Server setup for TAC Vista will not save the information when you change the user type from Windows account to TAC Vista account.
TAC Vista
TAC Vista OPC Server 1.6.1
This is a known issue that requires a specific reinstall procedure.
  1. Install version 1.6.0 of OPC Server
  2. Change to TAC Vista login in the TAC OPC setup
  3. Uninstall it
  4. Install 1.6.1 again.
For more OPC Server issues please Vista OPC Server Installation and Known Issues.
  • 4032
