BBMD and BBDT Enterprise Server or Automation Server
  • BBMD and BBDT Enterprise Server or Automation Server
  • RobertAndriolo
    RobertAndriolo
  • CraigEl
    CraigEl
  • Dave_Shore
    Dave_Shore
  • Cody_Failinger
    Cody_Failinger
  • sesa139513
    sesa139513
  • AdamSteele
    AdamSteele
  • RyanSuar
    RyanSuar
  • Sacco
    Sacco
‎2018-09-10 11:14 AM
Last Updated: Administrator CraigEl Administrator ‎2021-11-15 04:52 PM
  • Building Operation Enterprise Server and Automation Server
  • BBMD (BACnet Broadcast Management Device)
  • IP subnet, IP router
Clarification for both BACnet Broadcast Management Device (BBMD) and BACnet Broadcast Device Table (BBDT) when used within Building Operation servers.
A BBMD is needed when communicating to BACnet devices on another IP segment/subnet (across IP routers). One BBMD is required per subnet; this is because IP routers block broadcast packets and BACnet uses broadcast packets to initiate and maintain communications.
Continuum CyberStation (below) or bCX4 can act as a BBMD.
A BBMD can be created in a Building Operation Enterprise Server or Automation Server.
The BBMD on the other subnet should be as below
Now all the BACnet devices should be visible on both subnets
Notes
  • No more than a single BBMD should be created on each subnet for each IP port used.
  • Additional information about BBMDs is available on WebHelp The Teach and Learn commands are useful for larger networks with multiple BBMDs
Tags (4)
  • 7645
  • CraigEllis22
  • DavidShore21
  • enable
100% helpful (4/4)
