Posted: 2021-09-03 08:56 PM
Modicon M172 Can-Bus Master with TM172E28R slave
I am using a expansion module TM172E28R on a TM172PDG42R controller with Machine Expert - HVAC software.
I have setup my controller and software exactly like in this video from Schneider: https://www.youtube.com/watch?v=pyJA31G2yQk&list=PLa7UGrWOTyjlgMo0lD4eVCV0zFQYxbLoa&index=7
I have setup up the controller as Can-Bus Master address 125 and the TM172E as slave address 1, also the dip switches are set (4-5-6 all off), the dip switcdh number one is on and is the EOL resistor.
I have also added a 120 Ohm resistor on the Can-Bus terminal from the M172P.
Somehow i cannot get the Master running with the slave running.
The sys variables for the CANbus communication is all zero.
I also have a input from the expansion module in my watch and its always false (voltmeter shows me 24VDC).
Is there anything what I can try else? Or is there a setting i need to set that is not in the manual?
The Firmware of TM172P is "596.10".
Any help is appreciated. Thank you.
Michael
Training
Posted: 2021-09-09 01:48 AM
Did you made a download all? Only in that case the CONNEC.PAR which is used for the communication will be downloaded. On the expansion is near the CAN Port a LED. Is this LED flashing? What is the status of sysCANopenNodeStauts[3]?
- Tags:
- english
- Tags:
- english
Posted: 2021-12-15 02:57 PM
Thanks for your help, that LED was not flashing, it was a wire mistake on the bus.
It works now.
- Tags:
- english
Posted: 2023-07-26 12:25 AM
Posted: 2023-09-14 08:33 AM
any updates for this issue because i have the same problem ??? @Mick0275
